Re: How fast have you gone with a standard port bb head?
[Re: viperblue72]
#2215330
12/16/16 10:07 PM
12/16/16 10:07 PM
fast68plymouth
So. Burlington, Vt.
Thanks for the responses. I ask because I have a lowly 383 and I am putting portted sidewinder heads and a tr on it. But my future plan is to build a bigger short block eventually. My current combo is 12.5 to 1 trw domes, mp590 cam. 2800lb valiant. I'm hoping at least 10.7s. -12.5:1 383 -ported sidewinders -tunnel ram -590 cam -2800lbs Assuming it doesnt have a crappy converter and totally the wrong gear/tire combo, if that doesn't run at least 10.70's (at a track that's below 1500'-ish elevation), there's something seriously wrong with it.
[Re: viperblue72]
#2215355
12/16/16 10:50 PM
12/16/16 10:50 PM
Posts: 570 UK
rb446
UK
'69 Cuda stock 440-6pk bottom end, 9.8:1, 2.14/1.81 906's mild port, 3000lbs all in, CC.650/.650 290@.050 SFT cam, Team G dom w/adapter to 850DP, 727, stock front end w/90/10's, 4800 verter, Hoosier 14x32, 4.88's, l/bars c/overs
10.71@125 NA 1.46 60ft> 9.96@133.9 1.38 60ft with small Hit in 1990 11.23@118 with bone stock 906's.
I think it would've gone quicker with a cam where the intake closed somewhat earlier for a bit more effective stroke/CP....was at 0 sea, knowledge wasn't the best back then, like running 4psi in the slicks!
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: Dragula]
#2215617
12/17/16 01:41 PM
12/17/16 01:41 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
65 Belevadere all steel we have gone 10.94 on pump gas with 915 heads 2.14 / 1.81 valves....Its a pump gas 440 Source 526 stroker. Its got more in it, we are fighting traction since the car is not tubbed. Its fast, streetable and fun to drive. With a 526 that has to have some fast port speed
[Re: viperblue72]
#2215934
12/17/16 11:15 PM
12/17/16 11:15 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
My old DartSport had a low deck 451(400 block with 440 crank), MP 590 purpleshaft, ported Eddy heads, 727 with 8" ATI converter, 4.56 gears and 14x32 tires and weighed 3050# with me in it.
Ran 10.0's with a best of 9.96 in good air with a single Dominator.
Ran 9.90's with a best of 9.89 with a M1 TR and two 750 Quickfuel carbs. Extremely fun car, with 11.2 to 1 compression I ran pump gas on the street and mixed in a gallon of 110 octane as an additive. I'm guessing around 650HP. I don't have any photos on this new computer.
[Re: Clanton]
#2216353
12/18/16 05:17 PM
12/18/16 05:17 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
65 Belevadere all steel we have gone 10.94 on pump gas with 915 heads 2.14 / 1.81 valves....Its a pump gas 440 Source 526 stroker. Its got more in it, we are fighting traction since the car is not tubbed. Its fast, streetable and fun to drive. With a 526 that has to have some fast port speed And it likes a lot of carburetor.....1.50 60ft on that 3400 steel tank plus driver.
[Re: viperblue72]
#2216361
12/18/16 05:31 PM
12/18/16 05:31 PM
Posts: 570 UK
rb446
UK
Here's another combo, my mates 3150lbs Dart>
440, 12.7:1, MP.590sft, 273 rockers, MCH Eddy's (320cfm), Victor int, 1050 Dom, 5000 verter, SS springs, 4.56, 13x31's = 10.14@131
