Re: car lift
[Re: Crizila]
#2213131
12/13/16 08:36 AM
12/13/16 08:36 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Had one of theses at the dealer way back when... Loved that lift. Never realized they were not that expensive.(about 2gs) These are not my pics, just internet finds.
Re: car lift
[Re: Stanton]
#2213356
12/13/16 03:55 PM
12/13/16 03:55 PM
Posts: 3,530 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I don't have a high ceiling so I opted for one of these. Its somewhat mobile too. Compared to a creeper its the cat's a$$. How high is your ceiling? Thanks, Bill
Re: car lift
[Re: Stanton]
#2213549
12/13/16 09:59 PM
12/13/16 09:59 PM
Posts: 7,506 Az
Crizila
Az
9-1/2 feet. About a foot or so of clearance above the car with this one. Yes, I could probably have found a 2 or 4 post but I also don't want to have to work around posts right now. Maybe some time down the road. When I had my work shop / garage built, I contemplated adding a lift in the future, so I went with a 11'6" ceiling ( measured to the lights ). I also went with a roll-up door, so no door clearance issues - plus the door doesn't block any ceiling lights when it is up.
Fastest 300
Re: car lift
[Re: Crizila]
#2213559
12/13/16 10:20 PM
12/13/16 10:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
9-1/2 feet. About a foot or so of clearance above the car with this one. Yes, I could probably have found a 2 or 4 post but I also don't want to have to work around posts right now. Maybe some time down the road. When I had my work shop / garage built, I contemplated adding a lift in the future, so I went with a 11'6" ceiling ( measured to the lights ). I also went with a roll-up door, so no door clearance issues - plus the door doesn't block any ceiling lights when it is up. Being that I have the in concrete heating I made a map of the tubing so I can put the hoist in and not hit any of the tubing.... plus I went with 19' in the center peak area.. the walls are 12'.. 10x10 roll up door that I put a electric door opener on this year.. that mounts on the side of the door up where the shaft is(with the counter balance springs on it).. love that opener.. super quiet and has a automatic lock ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: car lift
[Re: MR_P_BODY]
#2213810
12/14/16 11:51 AM
12/14/16 11:51 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
90% of the time the 2 poster works great for what I do but yesterday I could have used a 4 post to align my front end(as long as it had the hyd jacks to lift it.. instead I put my Rampage on cinder blocks(2 blocks high) to do my finish readings.. which works great for me because if I have to pull any of the heims to make a adjustment I just lift the hoist CINDER BLOCKS?? Get some helmlock or jack stands. LOL Concrete blocks are not good to use. Matt
Re: car lift
[Re: MattW]
#2213814
12/14/16 11:55 AM
12/14/16 11:55 AM
Posts: 7,506 Az
Crizila
Az
90% of the time the 2 poster works great for what I do but yesterday I could have used a 4 post to align my front end(as long as it had the hyd jacks to lift it.. instead I put my Rampage on cinder blocks(2 blocks high) to do my finish readings.. which works great for me because if I have to pull any of the heims to make a adjustment I just lift the hoist CINDER BLOCKS?? Get some helmlock or jack stands. LOL Concrete blocks are not good to use. Matt You mean I just spent several $100 on turn tables when I could have used cinder blocks??? CRAP!!!!
Fastest 300
Re: car lift
[Re: MattW]
#2213818
12/14/16 12:10 PM
12/14/16 12:10 PM
MR_P_BODY
It works fine for me.. I'm not under the car.. I just have to get it high enough to see the gauge on the rotor and the steering arm.. plus the arms are right there... I had my 73 Ply fall on me years ago so I know all to well about cars falling.. that TANK crushed both of my shoulders... a week later a guy just a few streets away did the same thing.. he wasnt lucky.. crushed his.. head... now day(since back then) I am deathly afraid to get under a car without supports or a hoist ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: car lift
[Re: Cab_Burge]
#2213937
12/14/16 04:44 PM
12/14/16 04:44 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
What brand did you buy? I bought a cheaper one and wished that I had spent $300.00 more for a better one like the Benpacks I am in the market for a lift as well. My new building has 12' ceiling height. I am leaning toward a 2 post. Are there brands that should be avoided? Thanks, Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: car lift
[Re: Stanton]
#2214075
12/14/16 10:01 PM
12/14/16 10:01 PM
Posts: 5,115 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I only used the scissors at the door locations where the lift would be. The rest are flat bottom trusses and I will have some storage in those areas... Edit: Scissor trusses are in light yellow...flat bottom trusses are in light red...
...FAFO...
Re: car lift
[Re: skicker]
#2214106
12/14/16 10:35 PM
12/14/16 10:35 PM
MR_P_BODY
You can see the brown beam going around the building.. thats at 7'.. I am putting a 2' wide shelf most of the way around the place for storage.. I already have storage above the clean room/office... I didnt put it in front of the hoist or where I have cabinets.. I bought a bunch of Air Force steel wall lockers that are 8' tall so the shelf didnt fit there EDIT let me get a smaller pic... looks like I dont have any small pics... but there is a beam at 7'
Re: car lift
[Re: Crizila]
#2214354
12/15/16 12:35 PM
12/15/16 12:35 PM
Posts: 7,506 Az
Crizila
Az
11.5' ceiling. 8' roll-up door. Lift will go where that little red thing is sitting.
Fastest 300
Re: car lift
[Re: MR_P_BODY]
#2214382
12/15/16 01:06 PM
12/15/16 01:06 PM
Posts: 20,205 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'm so envious of you guys with nice lifts. I would love to have a four post lift but my 36-28 shop has 8 foot ceilings. I bought one of these 5-6 years ago and it help my old bones but its not anything like a lift. http://www.kwik-lift.com/uses.html
