Re: 71 - 74 Charger " NASCAR" hood? [Re: xjarhed] #221441
02/13/09 04:32 PM
02/13/09 04:32 PM
IL
71383beep Offline
71383beep  Offline
IL
Not sure on the wheel backspacing. The axle is a stock 8 3/4.
I am running 265/60/r15's on 15 x 8 cop car rims from stockton on all 4 corners and have plenty of room.
The hood looks like a 72-74 hood with the power bulge. I think 74 went vent less.
weird...
'73 GK6 Challenger Rallye - 340 4-Speed
Re: 71 - 74 Charger " NASCAR" hood? [Re: 71383beep] #221442
02/13/09 09:14 PM
02/13/09 09:14 PM
Ohio
tak Offline
tak  Offline
Ohio
I don't have pics because I don't own the car any longer, but I had a 72 Charger Ralley with the bulge hood and no louvers. It reminds you of the Ramcharger hood but non functional. Oh, the car was still all original paint so the hood was factory.
Re: 71 - 74 Charger " NASCAR" hood? [Re: tak] #221443
02/13/09 11:13 PM
02/13/09 11:13 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
The original hood for my '72 Rallye has the previously mentioned small gap in the louvers.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 71 - 74 Charger " NASCAR" hood? [Re: DynoDave] #221444
02/14/09 11:51 AM
02/14/09 11:51 AM
Ohio
tak Offline
tak  Offline
Ohio
My bad, I didn't understand the post correctly, my 72 charger had the louvers for the cowl just as the one above, I was thought you were talking about the fiberglass insert in the bulge. Sorry !
Re: 71 - 74 Charger " NASCAR" hood? [Re: tak] #221445
02/15/09 01:30 PM
02/15/09 01:30 PM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
A 74 Ralley hood.NO vents,(hope it posted).I will be using one on my my 71 because I like the clean sleek look of it.
'71 383HP FJ6 Charger SE
Re: 71 - 74 Charger " NASCAR" hood? [Re: 71 FJ6 Charger] #221446
02/15/09 04:02 PM
02/15/09 04:02 PM
IL
71383beep Offline
71383beep  Offline
IL
Now to really mix things up. this weekend at the World of Wheels car show in Milwaukee i talked with a guy who had his black on black 72 charger since he was 16 and never changed the rallye hood...it had no vents!
I'll post some pics later.
The mystery continues...
Re: 71 - 74 Charger " NASCAR" hood? [Re: 71383beep] #221447
02/15/09 05:09 PM
02/15/09 05:09 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Excuse me for getting off topic but where did you find 265/60x15 tires?
Re: 71 - 74 Charger " NASCAR" hood? [Re: 71383beep] #221448
02/15/09 10:38 PM
02/15/09 10:38 PM
NE Ohio
NE Ohio
Maybe he turned 16 and got it after 74!? just being a smart a s s.
Re: 71 - 74 Charger " NASCAR" hood? [Re: 71383beep] #221449
02/15/09 10:40 PM
02/15/09 10:40 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
No mystery...his hood was replaced.
When Mopar went to the "no vent" style hood, they ALSO switched the wiper squirters from being a hood mounting type, to a wiper arm mounted type. That happened in 1974. Ask that guy where his wiper squirters are located...I'll bet he's running the 74-later wiper arms as well. I'd also check the front underhood deflector...I'm willing to bet it was the shorter 73/4 version.
The factory supplied replacements (a.k.a. crash parts) used ALL styles, depending on when they were stamped. I've personally seen 71 Bee / R/T hoods with 73 cowl vents. Mopar never installed them this way...but they were available as crash replacement parts. Keep in mind, these parts WERE used to repair damaged cars, or if you bought parts over the counter. It's possible to have ANY year hood louver style, depending what was available at the time.
As for ORIGIONAL HOODS....
71 used 2 styles....all louvers with NO gap, OR louvers with ~2" gap
72 used the 2" gap on the majority of hoods...
73 used the 2" gap or the 8"? gap (I've not measure the actual gap, but there is quite a wide gap, with few louvers)
74 used the 8"? or NO louvers at all.
Also, you can put a 73/4 hood on the earlier 71/2 with no modifications( as far as installing them), however, if you try to put a 71/2 hood on a 73/4, IT WILL NOT CLOSE, unless you modify the underside deflector.
Re: 71 - 74 Charger " NASCAR" hood? [Re: 440trk] #221450
02/16/09 11:38 AM
02/16/09 11:38 AM
IL
71383beep Offline
71383beep  Offline
IL
thanks 440, I was wondering when you would come on here to straighten some of this stuff out.
I agree with you I think these are parts he modded over the years. It was a P coded 72 charger. As he was showing it to me I noticed the following:
1. standard shoebox dash
2. Rallye bulge hood w/ no vents - the bulge was also painted flat black
3. P on the vin which I thought was 400 - 2Bbl, but it was a 400 4 barrel (Tquad on tquad intake with the correct air cleaner)
4. E body style spoiler in the correct location
5. Definately a custom interior, but all of the creases and seams fit perfectly for a stock interior.
It was a very nice car, but something in me said there is NO WAY this is 100% stock.
On the hoods...did the hoods differ in 71 per factory or was it a mid year change?
Re: 71 - 74 Charger " NASCAR" hood? [Re: boydsdodge] #221451
02/16/09 11:41 AM
02/16/09 11:41 AM
IL
71383beep Offline
71383beep  Offline
IL
My cousin in law runs a Goodyear shop in Milwaukee.
I bought the Nascar Eagle 1's about 3 or 4 years ago.
He told me i was lucky because they were going to stop making them.
I like the yellow lettering...fitting for a super bee
Re: 71 - 74 Charger " NASCAR" hood? [Re: 71383beep] #221452
02/17/09 02:23 AM
02/17/09 02:23 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
Not sure I'll straighten ANYTHING out... but I'll help confuse, if given the oppertunity.
For what it's worth, you COULD get a 72 Rallye with the P-code 400 2v. Starting in 72, the 318 was the std Rallye engine, with the 340 4v, 400 2v, 400 4v, 440 4v, or the 440+6 as options.
HOWEVER... ALL 72-4 Charger Rallyes got the "rallye" dash instead of the std. bar dash
The ONLY way to get a buldge hood on a 72-4 Charger, was to order the Rallye package. The Buldge hood was NOT available on any other Charger.
So I'd say the guy had a standard Charger with the added goodies. Which is 100% acceptable, as long as you don't try to pass it of as original.
Wish I could honestly answer this for ya. I don't have enough info to make any informed statements on this. There are 2 71 R/Ts local to me that are low milage originals...I need to do some investigation work on which hood style they have and where/when they were produced. I'll keep ya posted.
