Re: Hemi rework disaster
[Re: The Shadow]
#2237104
01/19/17 01:52 AM
01/19/17 01:52 AM
Superfreak
Superfreak
I don't work there but do help out on projects He currently has my block.
[Re: 71birdJ68]
#2237488
01/19/17 08:54 PM
01/19/17 08:54 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
Manton heat treated,951-245-6565 Not cheap either, they take a and keep on keeping on Make sure you give them the thread size, count and length needed for the new adjusters
[Re: The Shadow]
#2237532
01/19/17 10:10 PM
01/19/17 10:10 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Something isnt right if you need 4 longer adjusters Unless 4 of them are just shorter than the other 12. Of course, if that isn't the case, then yes.........something isn't right.
[Re: 71birdJ68]
#2237619
01/20/17 12:16 AM
01/20/17 12:16 AM
Superfreak
Superfreak
Terribly frustrating with all the problems on a new build.
