Page 3 of 3 1 2 3
Re: Started my turbo build [Re: moparborn] #2276440
03/26/17 01:04 PM
03/26/17 01:04 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Sorry for all the questions. But what brand and size are the turbos?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Started my turbo build [Re: moparborn] #2276494
03/26/17 02:25 PM
03/26/17 02:25 PM
Pa. U.S.A.
moparborn Offline OP
Pa. U.S.A.
Turbo's and intercooler came as a kit from ebay,I will get the name for you(had them for a while and do not recall).
Had a few distractions this weekend but got some work done.
Drivers side cold piping.
Re: Started my turbo build [Re: moparborn] #2276498
03/26/17 02:27 PM
03/26/17 02:27 PM
Pa. U.S.A.
Pa. U.S.A.
Even made a few pipe spacers.
Re: Started my turbo build [Re: moparborn] #2276502
03/26/17 02:28 PM
03/26/17 02:28 PM
Pa. U.S.A.
Pa. U.S.A.
Throttle bodies are on.
Re: Started my turbo build [Re: moparborn] #2276513
03/26/17 02:39 PM
03/26/17 02:39 PM
Pa. U.S.A.
Pa. U.S.A.
Not sure of brand,generic most likely.
T70 turbos
Compressor:
Trim: 59
Inducer: 56.2
Exducer:72.9
A/R: 0.70
Turbine:
Trim: 62
Inducer: 73.9
Exducer: 58.3
A/R: 0.84
Re: Started my turbo build [Re: moparborn] #2278537
03/29/17 10:01 PM
03/29/17 10:01 PM
mopar65 Offline
mopar65  Offline
Thanks for the info. I have been looking at some of the GT45 turbos? I like that intercooler.
Re: Started my turbo build [Re: moparborn] #2280933
04/02/17 03:17 PM
04/02/17 03:17 PM
Pa. U.S.A.
Pa. U.S.A.
getting close to fire up.
Just need to do fuel system,vacuum system and a few miscellaneous things.
Re: Started my turbo build [Re: moparborn] #2280951
04/02/17 03:58 PM
04/02/17 03:58 PM
mopar65 Offline
mopar65  Offline
Damn that's turning out great.
Re: Started my turbo build [Re: moparborn] #2281103
04/02/17 08:25 PM
04/02/17 08:25 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
cool......post a video if possible.
Re: Started my turbo build [Re: moparborn] #2281358
04/03/17 06:48 AM
04/03/17 06:48 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Excellent job!
Re: Started my turbo build [Re: moparborn] #2289115
04/16/17 11:22 PM
04/16/17 11:22 PM
Pa. U.S.A.
Pa. U.S.A.
Well having some issues with the fitech,surprise surprise.
Intermittent spark(tried two different distributors),will have to troubleshoot this.
Re: Started my turbo build [Re: moparborn] #2291814
04/21/17 10:34 PM
04/21/17 10:34 PM
Pa. U.S.A.
Pa. U.S.A.
We are up and running.
Will get video tomorrow.
Was getting rf interference to the fitech,must insulate and isolate the wires for the distributor trigger.
Re: Started my turbo build [Re: moparborn] #2292056
04/22/17 12:55 PM
04/22/17 12:55 PM
Alberta
440_Offroader Offline
Alberta
Good to hear. I know when I put in my EZ EFI, I had all the wiring isolated. Separate power sources and grounds. I had heard of so many people having problems with installs, and much of it was the way wiring was routed. Glad you found your problem. Interested in seeing your video...
Re: Started my turbo build [Re: moparborn] #2292966
04/23/17 11:09 PM
04/23/17 11:09 PM
Pa. U.S.A.
Pa. U.S.A.
First video.
https://www.youtube.com/watch?v=Hck9r0npCow
Some more tuning to do and a few odds and ends.
Re: Started my turbo build [Re: moparborn] #2300640
05/07/17 12:37 PM
05/07/17 12:37 PM
Pa. U.S.A.
Pa. U.S.A.
Managed to get a few minutes to work on the truck this weekend,it is running pretty good for sitting in the garage.
Now to figure out the tuning,timing curve and retard,fuel map.
If I can get a dry weekend to put some miles on it.
Re: Started my turbo build [Re: moparborn] #2304278
05/14/17 01:03 PM
05/14/17 01:03 PM
Pa. U.S.A.
Pa. U.S.A.
Hit the road Saturday, ran good,had to tweek it a little,still will need adjustments.
Start up still gives me a little attitude ,have to open throttle a little ,starts up rich,prime set at 50,will keep dropping it.
Put about 2 pounds of boost to it,pulled good ( a little smile),then ? ,it started popping and running rough ,i am thinking bad things,get back to the garage,checked it over,relief, two plug wires came loose and melted on the headers,will not let that happen again.
Now to find out why the afr goes to 19-23 when letting off the thottle(not under boost),seems a little too lean for comfort.
Re: Started my turbo build [Re: moparborn] #2304295
05/14/17 01:22 PM
05/14/17 01:22 PM
Phoenix, AZ
MoPwer Offline
MoPwer  Offline
Phoenix, AZ
It should go lean when engine braking above about 1200 or so rpm. The injectors turn off.
-78 Utiline (5.7 Hemi)
Re: Started my turbo build [Re: moparborn] #2307871
05/20/17 12:20 PM
05/20/17 12:20 PM
Pa. U.S.A.
Pa. U.S.A.
Made it to the first cruise of the year.
Pleased with how it ran,still will need some tweeking as I go,I am not pushing too hard too fast,but it is pulling good,only put about 3 pounds of boost to it,no obvious lag.
Re: Started my turbo build [Re: moparborn] #2309746
05/23/17 01:26 PM
05/23/17 01:26 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Awesome, Love the color.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Started my turbo build [Re: moparborn] #2334059
07/09/17 01:30 PM
07/09/17 01:30 PM
Pa. U.S.A.
Pa. U.S.A.
Just another update ,got 200-plus miles on it, so far so good ,up to five and a half pounds of boost so far no complaints some minor tweaking as I go, if things go as planned I will be driving to Mopar Nationals
Page 3 of 3 1 2 3
