Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278688
03/30/17 01:15 AM
03/30/17 01:15 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Few weeks ago, I spent Saturday the morning getting all the fluids put in the car & the battery charged up to get ready to fire it up & break in the cam.
Got the cam broke in but had a bad oil leak which turned out to be me putting the rear main seal in backwards just on the cap 1/2.
Pulled it back out to address the rear main seal, didn't think the 1st oil change would be done in this fashion.
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278691
03/30/17 01:20 AM
03/30/17 01:20 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Really glad I went with the fenderwell headers. The ability to get them out of the way easily when pulling the motor really makes accessing to the bell housing bolts a breeze & allows easy access to the starter.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278692
03/30/17 01:21 AM
03/30/17 01:21 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Drove the car for the first time, about a mile, around the section to the back side of our land to stick it in the shop last night so I could put the Challenger in the garage before the hail storm.
Drives good & nothing unexpected happened but it was just a mile.
https://youtu.be/QPvqXyXF378
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278693
03/30/17 01:25 AM
03/30/17 01:25 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Pulled the axles & third member out to see what was in there. I knew it had the better of the 8 3/4" third member, the 742 case which from Mopar comes with a clutch type sure grip unit but could have been a peg leg & someone added a sure grip. Lukily it turned out to be the stock 742 clutch type & it looks all fresh & rebuilt & I checked it with a dial indicator & it's good. I did the initial count of the tire rev vs driveline revs & thought it was 4.10:1 & that's exactly what it turned out to be.
Put the rear end back together & it's ready to go. The thing is super clean underneath, not sure what they painted it with but it's a glossy black from below the firewall back to the rear valance.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278770
03/30/17 10:42 AM
03/30/17 10:42 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Its running but now it's got a slight water leak which I followed up to be a cracked block
I'll be pulling the motor at later, I put straight water in for now & it's just barely got a drip. The machine shop I used does the stitching technique for repairs like that & I'll be doing that to it.
This is the style repair I'll have done.
http://r-f.com/lock_n_stitch_repair.asp
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278771
03/30/17 10:46 AM
03/30/17 10:46 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Amazing what just polishing on the painted black parts of the interior can do. When wiping the dust/dirt off, it seems it is not going to shine up but with some aggressive polishing it just comes back to life.
The finned hood trim was gone & with everything else I had to buy I decided to go cheap on these so I bought some $25 pitted up swap meet ones. Figured I could paint them black & hit the high spots & around the edges with thinner & it may hide the pits. It worked out to look pretty good for cheap. Now to polish out the hood.
Since the car was backed in for rear ended work I finally got around to polishing out the decklid, roof, pass quarter/door. Found & got the bottom decklid trim on finally too. Chomping at the bit for the seats so I can really drive it.
Quite a change from when it rolled off the trailer.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278773
03/30/17 10:47 AM
03/30/17 10:47 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Too bad the new a-arm bushings that were already in the car are standard bushings. I need the offset bushings to try & get positive caster & with me having the higher front end ride height I need all the offset I can get.
The thing does have all new frontend parts in guessing from the when they reshot the under undercarriage.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2278804
03/30/17 12:04 PM
03/30/17 12:04 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Love it, looks like a fun ride when done. Great Daily Driver.
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2279121
03/30/17 09:30 PM
03/30/17 09:30 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Took some time but I got the seats back & he did an awesome job. No wrinkles & the material/pattern matches the originals I dropped off perfectly. Had to figure out how the rear fold down seat went together. I didn't disassemble it & its kind of an odd setup.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2279124
03/30/17 09:33 PM
03/30/17 09:33 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Thrashed on the car this past Friday night to get the front end back together & pulled the trans mount off due to a little leak from behind the mount & various other small issues. Ran over early Sat morning to get the seats I posted above, bolted the front seats up & got it road worthy just in time to get to the muffler shop 20 miles away just before thier cut-off time.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2279137
03/30/17 09:48 PM
03/30/17 09:48 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Exhaust is ran for now & sounds good. Kind of a quick & dirty / cheap way to mount it. I really like how it turned out & I was able to use the front seat bolt on the front side & slipped a bolt thru an existing hole on the torque box for mounting after the muffler.
Eventually I will run it from the backside, hidden on the collector just upstream of the collector flange. Run it inside & all the way out the back as a normal set-up. I'll run some butterfly electric dumps & you won't see any of it but the 1" thick butterfly dump.
2021 Toyota Supra
Re: 1967 Barracuda Formula S 383 daily driver build [Re: grancuda] #2282506
04/04/17 10:32 PM
04/04/17 10:32 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Took the Barracuda out & about around town this past Saturday just tinkering with the timing, trans shift points & carb. It's running really good, pulls good and all. But after checking out stuff tonight it seems my crack has grown. I'm going to take my other 383 I have up to the machine shop Monday & just have him prep it & I will just swap all my stuff out & into it.
Little dirt road to the shop.
I cleaned the old crack with brake kleen 2 weeks ago to get all the blue engine paint off then since it pretty much is non-visible as bare metal I used a white paint pen to outline it. Seems the whole side of the block was weak from a water freeze at some point in the past. Glad I decided to drive it a little before pulling it & getting it repaired.
2021 Toyota Supra
