car lift
#2212499
12/12/16 02:31 PM
12/12/16 02:31 PM
Posts: 7,506 Az
Crizila
Az
Just bought a 4 poster for my shop. Will pick it up Wednesday. "Some assembly required". Think the wife might be taking my creeper away from me? I know she despises it.
Fastest 300
Re: car lift
[Re: Stanton]
#2212529
12/12/16 03:14 PM
12/12/16 03:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'll be buying a new 2 poster to replace my current 2 post.. mine doesnt go quite high enough for me and I bang my head on the arms.. the new one will go up another 10" higher.. the one I have now I bought used when I built my shop... its worked fine but just isnt high enough.. $2400 gets me the new one.. already have it picked out.. my buddy has the same one right now... its NICE
Re: car lift
[Re: Crizila]
#2212573
12/12/16 04:10 PM
12/12/16 04:10 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I have a 4 post in the garage on my house. I mostly use it as added parking, but it's great. Thinking of adding another. Just make sure whats on top doesn't leak or you have a drip pan............LOL!!!!
I keep my boat on the one I have. Boats aren't used every day and still have use of garage. Works out great
I want to put another drive on and a 2 post in my shop, just haven't gotten around to it
Re: car lift
[Re: Cab_Burge]
#2212577
12/12/16 04:14 PM
12/12/16 04:14 PM
Posts: 7,506 Az
Crizila
Az
What brand did you buy? I bought a cheaper one and wished that I had spent $300.00 more for a better one like the Benpacks Went with "Advantage Lifts, LLC." Saw it at SEMA and liked a lot of the features - 9000 lb cap., mobile ( caster kit standard), 36" aluminum ramps, rolling jack tray, drip trays, adjustable upper limit stop switch, double safety's on mechanicals / hydraulics - all standard. I did buy 2 options - rolling air/hyd. jack and light kit. Got a good SEMA discount on all.
Fastest 300
Re: car lift
[Re: Crizila]
#2212587
12/12/16 04:31 PM
12/12/16 04:31 PM
Posts: 10,049 MN
JERICOGTX
MN
I have a mid lift from Rotary. Makes life MUCH easier. It works perfect to doing body work. I can remove all the front and rear suspension from the car on the lift also. In s perfect world, I'd have 3 lifts. A 2 post, 4 post, and this.
69 GTX
68 Road Runner
Re: car lift
[Re: JERICOGTX]
#2212621
12/12/16 05:29 PM
12/12/16 05:29 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have a mid lift from Rotary. Makes life MUCH easier. It works perfect to doing body work. I can remove all the front and rear suspension from the car on the lift also. In s perfect world, I'd have 3 lifts. A 2 post, 4 post, and this. I noted that you have straps on the front subframes as insurance for when you are doing chinups off the rear bumper off that B-Body I am saving my pennies for a 4 post...I am too old to get down on the ground to position the lift arms and still want to be able to walk all the way from front to back under the middle of the car. I will buy two jack trays. My shop has 14' ceilings so clearance is not a problem.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: car lift
[Re: Polarapete]
#2212639
12/12/16 05:47 PM
12/12/16 05:47 PM
MR_P_BODY
90% of the time the 2 poster works great for what I do but yesterday I could have used a 4 post to align my front end(as long as it had the hyd jacks to lift it.. instead I put my Rampage on cinder blocks(2 blocks high) to do my finish readings.. which works great for me because if I have to pull any of the heims to make a adjustment I just lift the hoist
Re: car lift
[Re: JERICOGTX]
#2212647
12/12/16 06:03 PM
12/12/16 06:03 PM
Posts: 7,506 Az
Crizila
Az
I have a mid lift from Rotary. Makes life MUCH easier. It works perfect to doing body work. I can remove all the front and rear suspension from the car on the lift also. In s perfect world, I'd have 3 lifts. A 2 post, 4 post, and this. All the bases covered.
Fastest 300
Re: car lift
[Re: Crizila]
#2212712
12/12/16 07:53 PM
12/12/16 07:53 PM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I noted that you have straps on the front subframes as insurance for when you are doing chinups off the rear bumper off that B-Body Those straps are necessary when the pads are on the rear crossmember - there's too much rear end weight.
Re: car lift
[Re: justinp61]
#2212715
12/12/16 08:06 PM
12/12/16 08:06 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
I bought an Atlas 9000# two post lift two or three years ago and love it. In the winter I keep my Dart on it and the mower and four wheeler under it. Got one of each...4 post and 2 post...Both are Atlas..going on 3 yrs now.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: car lift
[Re: 70AARcuda]
#2212726
12/12/16 08:22 PM
12/12/16 08:22 PM
MR_P_BODY
I want to see if a 4 poster will swing around the new 2 post that I am buying.. if it will clear I might pick a 4 poster also so I can have 1 car on it and another car below.. then my Rampage on the 2 poster and my Jeep under it.. I can get 4 cars in my shop now and it fills up 2/3rd of the shop.. the other 1/3 is my machine shop area and no way can I get any car over there
Re: car lift
[Re: Crizila]
#2212777
12/12/16 09:30 PM
12/12/16 09:30 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
I bought a budget four post lift about 10 years ago when the wife and I built our house and detached garage. I specifically had 11 1/2' tall ceilings put in the garage along with a high lift garage door. I contacted the lift vendor who put me in contact with a local company that sold their lifts. I had the local place deliver and assemble the lift in my garage so there would be no excuses that I installed the lift incorrectly should the lift have any issues. It is been a great investment and very useful tool. Mine came with extra drip trays, a jacking tray and casters. I did not bolt mine to the floor so I can lower the lift down on the casters and roll the lift anywhere I want in the garage or even out into the driveway if needed. It's great for doing mechanical work on cars with the wheels on or off and creates well needed extra storage space when stacking cars. The only issue I've had with it is I had to have new seals installed in the main hydraulic cylinder last summer as it was dripping very lightly but I have no complaints after 10 years of service. I'm also thinking of buying another.
Re: car lift
[Re: Stanton]
#2212825
12/12/16 10:35 PM
12/12/16 10:35 PM
Polarapete
Graham, WA
I noted that you have straps on the front subframes as insurance for when you are doing chinups off the rear bumper off that B-Body Those straps are necessary when the pads are on the rear crossmember - there's too much rear end weight. I knew that...sometimes you are just too literal. I used to work in a wrecking yard and when we moved the cars around, whether they were equipped with an engine or not, we would slide the forklift forks under the front of the car and wrap a chain on each side over the frame rail and around the fork to keep it from tipping over...you have no idea how much noise it makes when you drop a Buick on it's a$$ and have to explain that to the boss.
