1973-74 e body caliper bracket identification #2211466
12/10/16 07:50 PM
12/10/16 07:50 PM
Connecticut
biginchmotor Offline OP
Connecticut
I am looking for caliper mounting brackets for stock disc brake spindles for the 73-74 e body. Are there specific part numbers I should look for? Is there a left and right side bracket? Thanks for any help, John.
Re: 1973-74 e body caliper bracket identification [Re: biginchmotor] #2211487
12/10/16 08:16 PM
12/10/16 08:16 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
There is no left and right bracket.
They are all the same thing, side to side.
Numbers cast in them won't mean anything to you, or me.
They meant something at the foundry, but thats all.
Mounts for the standard 10.8 inch rotors are common, and pretty easy to find, and buy.
There are some differences in mounts between early 70's and mid to later 70's, but i never ran into any problems, mounting calipers.
Caliper Mount Differences 001 (Copy).JPGCaliper Mount Differences 004 (Copy).JPGCaliper Mount Differences 005 (Copy).JPG
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 1973-74 e body caliper bracket identification [Re: biginchmotor] #2211498
12/10/16 08:26 PM
12/10/16 08:26 PM
'73-'76 a body calipers are the same so include that group in your quest (they ain't cheap tho these days)
Re: 1973-74 e body caliper bracket identification [Re: RapidRobert] #2211502
12/10/16 08:41 PM
12/10/16 08:41 PM
hemi71x Offline
hemi71x  Offline
Wrong.
That's incorrect information.
73-76 A body cars use "Slider" type calipers.
70-74 E body cars use "Pin Type" calipers.
And then caliper mounts are different between the caliper designs.
Re: 1973-74 e body caliper bracket identification [Re: hemi71x] #2211552
12/10/16 10:08 PM
12/10/16 10:08 PM
Oh OK I thought the 73/74 E's were sliders too. My bad
Re: 1973-74 e body caliper bracket identification [Re: RapidRobert] #2211602
12/10/16 11:39 PM
12/10/16 11:39 PM
Connecticut
Connecticut
Thank you for the help with the information and pictures. I always wondered if the left and right brackets were the same. John.
