Re: Comp "Sportsman"roller lifters with Bronze Bushing?
[Re: 70satelliteguy]
#2210718
12/09/16 03:33 PM
12/09/16 03:33 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If you can get them for only a couple hundred more than 829's, get em. They are normally almost twice the cost .
#2211218
12/10/16 02:08 PM
12/10/16 02:08 PM
fast68plymouth
So. Burlington, Vt.
I have a couple of customers running them in unbushed stock blocks with no issues, although I haven't put them in a motor myself(although I would).
The pushrod seat height spec is the same as the 829's.
