Re: Hemi engine rant
[Re: DUSTER_340]
#2210106
12/08/16 03:51 PM
12/08/16 03:51 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
Care to share any photos of the block. I have a bare block I am going to be using for a project and would definitely like to know what Identification marks your block has on it. I doubt ID marks are going to tell you anything ... put a seal cap in the block and it should be fairly easy to see if it's off.
[Re: Crizila]
#2210132
12/08/16 04:41 PM
12/08/16 04:41 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Are you running the factory correct PCV valve? Have you checked to see if the crankcase is running in a vacuum at idle and cruise? A couple of suggested band-aids. Use a mechanical vacuum pump and get a custom made diaper with absorbent. Change the absorbent when needed.
[Re: sasquatch]
#2210381
12/08/16 11:04 PM
12/08/16 11:04 PM
Posts: 1,138 Home of the Bluegrass
MoparJunkie
Todd, the piston went out today... thanks again for talking me off the ledge! Greg
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
[Re: roadhazard]
#2210464
12/09/16 01:47 AM
12/09/16 01:47 AM
MoparJunkie
Greg, I'll get the seal info this weekend. Thanks
[Re: MoparJunkie]
#2212731
12/12/16 08:33 PM
12/12/16 08:33 PM
MoparJunkie
And yes Todd, when I put the orange seals side by side with the black ones, the orange seem to be a bigger seal??? You were correct!
[Re: MoparJunkie]
#2213415
12/13/16 05:48 PM
12/13/16 05:48 PM
MoparJunkie
Good deal work your magic and order me some up. You know the deal! Thanks, Todd!
