Re: Hemi engine rant [Re: roadhazard] #2210085
12/08/16 03:09 PM
12/08/16 03:09 PM
Home of the Bluegrass
MoparJunkie Offline OP
Greg, I am currently tearing it down myself... I have found some other issues to make me never deal with Stanton Racing ever again. I don't even have the pistons I was told were being used.... they did install a .010" shim under the block side of the seal. However they are using Felpro seals. I've also discovered rod bearing scoring on 6 of 8 rods. This motor only has a 1000 miles on it at best. With the oil and filter changed twice in that time. The piston installed and the ones I was told was installed are 1 full point of compression lower. I.e.... I'm at 9.5-1 instead of the 10.2-10.5 I was told it would be. Just a very bad experience. twocents
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: Hemi engine rant [Re: DUSTER_340] #2210106
12/08/16 03:51 PM
12/08/16 03:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By DUSTER_340
Care to share any photos of the block. I have a bare block I am going to be using for a project and would definitely like to know what Identification marks your block has on it.
I doubt ID marks are going to tell you anything ... put a seal cap in the block and it should be fairly easy to see if it's off.
Re: Hemi engine rant [Re: MoparJunkie] #2210123
12/08/16 04:28 PM
12/08/16 04:28 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Usually a picture is worth a thousand words......
I can describe that one in three....... Has No Clue!
That may be one of the great contributors to the leak. Installing a shim on the back side of the seal thinking it's going to reduce the lip I.D. for a greater interference fit on the crank surface is misguided at best.
That's like taking a .010" under crank and using standard bearings with a .010" shim behind them thinking your going to cure the clearance problem...... AIN'T GONNA HAPPEN!
Get out your magnifying glass and tell me the numbers/letters that are molded into the seal lip area please.
Re: Hemi engine rant [Re: Crizila] #2210132
12/08/16 04:41 PM
12/08/16 04:41 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Originally Posted By Crizila
Are you running the factory correct PCV valve? Have you checked to see if the crankcase is running in a vacuum at idle and cruise?
A couple of suggested band-aids. Use a mechanical vacuum pump and get a custom made diaper with absorbent. Change the absorbent when needed.
Re: Hemi engine rant [Re: BobR] #2210350
12/08/16 10:12 PM
12/08/16 10:12 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Greg
I have already began to show our poster the ways of the force......we will get it right......Todd
Re: Hemi engine rant [Re: sasquatch] #2210381
12/08/16 11:04 PM
12/08/16 11:04 PM
Todd, the piston went out today... thanks again for talking me off the ledge!
Greg
Re: Hemi engine rant [Re: roadhazard] #2210464
12/09/16 01:47 AM
12/09/16 01:47 AM
Greg, I'll get the seal info this weekend. Thanks
Re: Hemi engine rant [Re: MoparJunkie] #2210615
12/09/16 12:22 PM
12/09/16 12:22 PM
Winterpeg, Canada
hvyweight Offline
hvyweight  Offline
Winterpeg, Canada
Same issue...made three attempts with seals gave up went to a rope seal....no leaks!
Re: Hemi engine rant [Re: roadhazard] #2212460
12/12/16 01:15 PM
12/12/16 01:15 PM
Greg black seals with felpro on the side, p-91020-1 in the middle and a 6 on the other side.
Re: Hemi engine rant [Re: MoparJunkie] #2212731
12/12/16 08:33 PM
12/12/16 08:33 PM
And yes Todd, when I put the orange seals side by side with the black ones, the orange seem to be a bigger seal??? You were correct!
Re: Hemi engine rant [Re: MoparJunkie] #2212758
12/12/16 09:13 PM
12/12/16 09:13 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Your piston came today. I will weigh it in the AM. Todd
Re: Hemi engine rant [Re: MoparJunkie] #2213415
12/13/16 05:48 PM
12/13/16 05:48 PM
Good deal work your magic and order me some up. You know the deal! Thanks, Todd!
