Page 11 of 16 1 2 9 10 11 12 13 15 16
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2288979
04/16/17 06:59 PM
04/16/17 06:59 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
That look great and is a major milestone. Stuff like that just makes you work harder. Congratulations!!!
Re: OK! No more BS. Time to start working. [Re: killermopar] #2289033
04/16/17 08:34 PM
04/16/17 08:34 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Good job...... Can't wait to here what it runs.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2289164
04/17/17 12:39 AM
04/17/17 12:39 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
It's looking really good. Nice pic up
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2289295
04/17/17 10:31 AM
04/17/17 10:31 AM
an8sec70cuda Offline
Looks nice Kenny!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2289422
04/17/17 02:04 PM
04/17/17 02:04 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
This is a hell of a lot of work. Good progress, keep it up.
Doug
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2289653
04/17/17 08:49 PM
04/17/17 08:49 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Thanks, guys. I don't think she will be ready by May for the Nostalgia Pro Stock races, but I sure am going to try to make some runs by summer.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2289848
04/18/17 01:15 AM
04/18/17 01:15 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Looks like it's at a point to load it up and take it down and have the inspector look it over... smile smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: OK! No more BS. Time to start working. [Re: racerhog] #2289854
04/18/17 01:27 AM
04/18/17 01:27 AM
sgcuda Offline OP
sgcuda  Offline OP
Almost. Have to add the passenger X brace and a couple of small supports up front. Steering column should be here this week. New front struts just ordered tonight. Hopefully it will be a full roller within 2-3 weeks.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2289856
04/18/17 01:31 AM
04/18/17 01:31 AM
racerhog Offline
racerhog  Offline
Awesome Job So Far... Keep on Chipping at it.. smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2302086
05/09/17 11:17 PM
05/09/17 11:17 PM
sgcuda Offline OP
sgcuda  Offline OP
Looks like Christmas is coming to my house very soon. penguin
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2303589
05/12/17 10:33 PM
05/12/17 10:33 PM
sgcuda Offline OP
sgcuda  Offline OP
Well, I picked up a new Comp Engineering motor plate to stiffen the snout bars, got a MSD 7AL-2, ordered a fiberglass nose mounting kit, steering rack mounts, and door hinge kit through Chassis Engineering. After 3 weeks, finally got my new front strut kit from Strange. Still waiting on my backordered steering column kit from Jegs. But best of all, my Indy block showed up today!
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2303596
05/12/17 10:49 PM
05/12/17 10:49 PM
fullmetaljacket Offline
Nice Alloy.
Keep it up.
Re: OK! No more BS. Time to start working. [Re: fullmetaljacket] #2303643
05/13/17 12:26 AM
05/13/17 12:26 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Can't leave well enuff alone..............you're HOOKED........... boogie
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2305040
05/15/17 06:41 PM
05/15/17 06:41 PM
Nice! How big is the new bullet gonna be?
Why the 7al2? The 7al3 has so many more features.
CHIP
Re: OK! No more BS. Time to start working. [Re: an8sec70cuda] #2305067
05/15/17 07:34 PM
05/15/17 07:34 PM
sgcuda Offline OP
sgcuda  Offline OP
Block is already 4.560. RBRE will check for sleeve replacement. I know 1, maybe 2 sleeves are damaged. If all need replacement, I will resleeve it at 4.500. I have a set of Manley rods with .990" small end and 2.100" big end. I'm going to offset grind my Eagle crank as much as possible from 4.15 to hopefully 4.40. So the engine will end up anywhere from 560 to 575 cubes. I got the 7AL-2 on the cheap in real nice condition. I only need a launch limiter and high end limiter, so I don't need a lot of features anyway.
[image][/image]
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2312615
05/28/17 09:59 PM
05/28/17 09:59 PM
sgcuda Offline OP
sgcuda  Offline OP
Today has been an historic day! I finally got the car down on all four tires after almost a year and a half. Made my own coil spring compressor for the struts. Before the day was done, I even got the Indy block in place with the trans bolted in.
Strut spring compressed.jpgStruts installed.jpgCar on all fours.jpgIndy block in bay.jpg
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2312616
05/28/17 10:01 PM
05/28/17 10:01 PM
sgcuda Offline OP
sgcuda  Offline OP
If anyone needs to borrow the spring compressor, just pm me. It will compress 7" springs for Strange struts.
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2312618
05/28/17 10:03 PM
05/28/17 10:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Gettin after it again.............good deal and will be blasting down the street before you know it........... beer
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2312720
05/29/17 12:51 AM
05/29/17 12:51 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
up up
Re: OK! No more BS. Time to start working. [Re: sgcuda] #2312824
05/29/17 10:14 AM
05/29/17 10:14 AM
Parts unknown
590 Challenger Offline
Parts unknown
I was just checking out your very cool build, very nice
