Port intake and Convert to EFI #2207118
12/03/16 08:02 PM
12/03/16 08:02 PM
St. Louis, MO
mopardamo Offline OP
St. Louis, MO
I have a Mopar 337 single plane for a 528" engine with RPM heads that have MCH Max wedge type porting. Who would you use for EFI conversion and porting for a street/strip deal?
Damon
Re: Port intake and Convert to EFI [Re: mopardamo] #2207120
12/03/16 08:12 PM
12/03/16 08:12 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If there is an Intake you like that can be purchased setup for EFI I would go that route. I asked around a little about converting my Intake to EFI and I got prices around $400-500 so I just got a Super Victor EFI for my small block. If you have an intake that you really want to keep then check with some performance shops in your area. I understand why they charge so much it just didn't make sense for me when I could by a whole intake for less money. I had to make fuel rails for my other EFI intake and that was time consuming even with mill access.
68 Barracuda Formula S 340
Re: Port intake and Convert to EFI [Re: Bad340fish] #2207123
12/03/16 08:25 PM
12/03/16 08:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its not hard to do if you have the equipment...
I can do it.. but it depends on the porting...
I do all my own porting and EFI rails for multi
port... I dont know if the 337 manifold needs to
have bungs welded on or not... if you want you can
sent me a PM
wave
Re: Port intake and Convert to EFI [Re: mopardamo] #2207124
12/03/16 08:25 PM
12/03/16 08:25 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
An EFI conversion on an intake is labor intensive and time consuming. I get $550 for most. Yes, sometimes you can buy EFI ready intakes for less but choices are very limited
Re: Port intake and Convert to EFI [Re: mopardamo] #2207176
12/03/16 09:25 PM
12/03/16 09:25 PM
St. Louis, MO
St. Louis, MO
If I changed my intake choice what one would be best. I have the T/A hood so I do have some extra clearance for a taller manifold. It's a tall deck block and the ports are roughly Max Wedge sized and the E body has 3.54 gears. 10.7 cr and cam @.05 260, 268 adv. 290, 305 .431, .440. This is mostly a street deal with a few weekends a year at the strip.
Hey Mr P you have a PM.
Re: Port intake and Convert to EFI [Re: mopardamo] #2207216
12/03/16 10:16 PM
12/03/16 10:16 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I think your intake choice is fine. It even has the FI bosses built into it. You stated the heads are already ported to maxwedge so you should be pretty close to a port match or better with that intake, since its ports are a little smaller then MW.
Seems you just need someone to install a fuel rails and bungs. Since the bosses are already there, I bet its something you could do yourself with a little research.
With FI I would definitely Keep that intake. up But if you decide you don't want it, I can take it off your hands devil
Re: Port intake and Convert to EFI [Re: mopardamo] #2207257
12/03/16 10:52 PM
12/03/16 10:52 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Wilson Manifold
