Re: paint job on a budget!?
[Re: dalbers]
#22091
03/08/06 09:14 AM
03/08/06 09:14 AM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
dalbers - interesting, seems like your learning the tequnique. your test area is nice and easy to work with. from what i see you need to thin just a BIT more, and when wetsanding, maybe try 600 grit until the 4th coat and then go to 800. when you prep, it's not nessessarly better to go with a fine grit paper, i would prep to 400 grit max. it's hard to tell from you pics, but i would say you need to wetsand more, until the paint looks like a perfect "flat" finish with no high/low spots or marks at all. keep up the good work, obviously continue with just that hood, until you perfect and get a "feel" for the process, soon grasshopper, soon you will be ready.
#22092
03/08/06 09:26 AM
03/08/06 09:26 AM
69chargeryeehaa
toronto canada
Been following this thread forever now, and i finally ahve some funds to experiment. For everyoen continuing to post, thanks for all the valuable information.
Im going to try the fender of my car tomorrow, and what I wanted to ask was, when I do it, the stock paint (from 85) is still there, can I just remove the silicone and any other oils, sand, then paint over it?
sand the car down with 200, then really clean the car good with mineral spirits a few times. make sure you sand until there's no "shine" at all in the original paint. then sand with nothing finer then 400. paint right over the original paint.
[Re: Kam*Kuda]
#22095
03/08/06 11:32 AM
03/08/06 11:32 AM
69chargeryeehaa
toronto canada
funny, the doorbell just rang and i got a case of tremclad paint, and a case of clear coat from the good ol' boys at tremclad, and it's not even my birthday!!!
You have increased Tremclad sales. Soon you will be the president.
i'm not only the president, i'm also a client
#22096
03/08/06 01:07 PM
03/08/06 01:07 PM
Still waiting for pics Ricklandia??
Tonight. By the time I got finished last night it was past 1AM, I couldn't even find the energy to take photos.
[Re: dalbers]
#22098
03/08/06 02:12 PM
03/08/06 02:12 PM
69chargeryeehaa
toronto canada
thanks 69charger, i'll wet sand some more tonight. How soon are you going to experiment with that clear?
ummmm, not sure when, i might just try a test peice, but i don't have a old hood hanging around. don't really feel like stripping my whole car again to add 10% more shine, but next time i need to paint it i'll defineatly try it out. interesting it says on the can to clean the surface with mineral spirits, then thin the clear with laquier thinner......interesting.... also it says to wait at least 72 hours if painting over the tremclad rust paint. it's worth a shot, espically then you'd only have to make the base color smooth and uniform, you could clear after wetsanding to a perfect finish and then buff and wetsand/polish the clear, also i opened the clear coat can up and it's allready as thin as i would like it to paint, so i don't even think i would thin the clear at all, but it looks nice in the can!!! maybe i'd thin it 2-5% just so it would increase the pot life/work time a bit...... ......the more i think about it, i really see potential for BC/CC quality, allthough it would'nt be a $50 paint job any more!!!, more like $70!!!!but the results would be . when i expiremented with it years ago i thinned with mineral spirits, and the tremclad dude said that will KILL the shine completely. i guess i should have read the can before using it.
[Re: dalbers]
#22100
03/08/06 03:15 PM
03/08/06 03:15 PM
Posts: 3,379 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
I'll look if rustoleum makes the clear and maybe test it out.
They do make the clear. So far I've tried home depot and lowes and they didnt have it except for the can. I am going to see if that kelly moore that carries rustoleum in my area has the clear in pint or quarts.
[Re: davesdartgt]
#22101
03/08/06 04:08 PM
03/08/06 04:08 PM
Posts: 18,059 S.E. Michigan
ZIPPY
S.E. Michigan
I'm looking to spend $50 total. Once you start buying hardeners, reducers, etc automotive paint is alot more expensive than a gallon of Rustoleum & a gallon of mineral spirits. The truck is only worth $3500 tops. The Challenger will get painted with top of the line PPG, but the Ram will get Rustoleum or Tremclad at this point.
Check out the Duplicolor line (gallons, limited colors) at Murray's auto parts.
[Re: ZIPPY]
#22102
03/08/06 04:42 PM
03/08/06 04:42 PM
69chargeryeehaa
toronto canada
this car was painted with duplicolor paint: http://i32.photobucket.com/albums/d13/69martin/DSC00194.jpg
but when you factor the paint, primer, primer sealer, and acetone, ect....i still needed to crack into a 2nd can of paint for the beetle. so in the end i spent about $60 x 2 gal of paint, $40 primer, $40 primer sealer, $40 reducers, for a total of $240 in paint. then you have to spray it, which was the main reason i rollered my car in the first place.
but the duplicolor paint was very good paint for the $, i've used it on 2 cars and it's good paint, but for those who don't want to spray, the roller method is the next best thing.
[Re: 69chargeryeehaa]
#22103
03/08/06 09:05 PM
03/08/06 09:05 PM
Project Beer Fridge - Part 3
Taking a night off tonight, at least no painting. Consolidated some photos for posting. Image #1: Yes, its Beer Fridge in all her glory.
#22104
03/08/06 09:07 PM
03/08/06 09:07 PM
Another shot - sanded down and ready for her new clothes.
[Re: Exit1965]
#22105
03/08/06 09:09 PM
03/08/06 09:09 PM
Exit1965
Rancho Cordova, CA
I may have lied.. I can't find non-spray CLEAR by rustoleum anywhere online, and what I understood about my kelly moore was wrong-they only have the industrial line (and no cheap clear coat of any kind).
Perhaps someone else in the USA makes a clear enamel (it's still an enamel right?) in a non-spray and that can be brushed or rolled on?
Funny thing, I can't find any website that sells tremclad either. Are there laws in canada against selling paint online or something?
#22106
03/08/06 09:14 PM
03/08/06 09:14 PM
Day one - two coats applied. First coat went on too thick, second better. The front doors are the worst, sides are better.
#22107
03/08/06 09:14 PM
03/08/06 09:14 PM
#22108
03/08/06 09:18 PM
03/08/06 09:18 PM
Day two: Wetsanded with 400 grit and applied coats 3 and 4. Paint was mixed much thinner for these coats. Surface looks pretty good save the dog hairs.
#22109
03/08/06 09:20 PM
03/08/06 09:20 PM
Tight shot with a flash reflection. This was taken today after the paint had 24 hours to dry, no sanding done.
