Re: 33 plymouth 2 dr. sedan
[Re: moparx]
#2236720
01/18/17 02:08 PM
01/18/17 02:08 PM
Posts: 2,505 Shelby, Ohio
2abodymcodes
Shelby, Ohio
the interior is whatever the wife picks out. All the interior metal trim and dash will be a Kameleon color that changes. It's called Rosey Purpleen. It will be this color.
[Re: 2abodymcodes]
#2239048
01/22/17 02:29 PM
01/22/17 02:29 PM
Posts: 7,506 Az
Crizila
Az
the interior is whatever the wife picks out. All the interior metal trim and dash will be a Kameleon color that changes. It's called Rosey Purpleen. It will be this color. Awesome!! I basically did the same thing with my 33 Coupe - "interior is what ever the wife picks out". There are some things that are better left up to the lady of the house so to speak. Interiors are one of them IMO. I would have ended up with some cheap bucket seats in basic black with a steering wheel and gauges to match, but ended up with - - - - thanks to the wife.
Fastest 300
[Re: Crizila]
#2241459
01/26/17 02:00 AM
01/26/17 02:00 AM
Posts: 26 British Columbia, Canada
cocobolo
the interior is whatever the wife picks out. All the interior metal trim and dash will be a Kameleon color that changes. It's called Rosey Purpleen. It will be this color. Awesome!! I basically did the same thing with my 33 Coupe - "interior is what ever the wife picks out". There are some things that are better left up to the lady of the house so to speak. Interiors are one of them IMO. I would have ended up with some cheap bucket seats in basic black with a steering wheel and gauges to match, but ended up with - - - - thanks to the wife. Very nice. Do you have a build thread anywhere on your car?
[Re: cocobolo]
#2241772
01/26/17 04:43 PM
01/26/17 04:43 PM
Posts: 7,506 Az
Crizila
Az
the interior is whatever the wife picks out. All the interior metal trim and dash will be a Kameleon color that changes. It's called Rosey Purpleen. It will be this color. Awesome!! I basically did the same thing with my 33 Coupe - "interior is what ever the wife picks out". There are some things that are better left up to the lady of the house so to speak. Interiors are one of them IMO. I would have ended up with some cheap bucket seats in basic black with a steering wheel and gauges to match, but ended up with - - - - thanks to the wife. Very nice. Do you have a build thread anywhere on your car? Go to Custom33 on face book. Owner of the company posted lots of pics of my build.
Fastest 300
[Re: Crizila]
#2243415
01/29/17 02:43 PM
01/29/17 02:43 PM
2abodymcodes
Shelby, Ohio
Finally getting it back together. Spent all day Saturday setting the body back on the frame.
Don't know why, but it won't let me download pictures today.
[Re: 2abodymcodes]
#2244619
01/31/17 11:51 AM
01/31/17 11:51 AM
Posts: 7,506 Az
Crizila
Az
Looking good!! You are making great progress. Anxious to see how all the periphery's (HVAC, wipers, electrical, etc ) are all going to go in. Since I have reverse mounted ( under the dash ) dual Wilwood masters, space went from tight to TIGHT between the dash and firewall on my build. I went with the smallest Vintage air unit available. Still ate up the entire right side of the under dash area. Ducting for 3 levels of heat ( defrost, mid, floor) also killed lots of space. Wiper system sits directly in front of the heater box. If I had to do it again, don't think I would have installed a wiper system. Rain-X just works too good! I did split up my electrical system. My battery and controls for the power door locks and windows are located behind the seat with access doors in the trunk front wall. Main fuse panel is located in the center area under the dash in a swing down panel ( that don't swing down much anymore) for easy access - NOT!
Fastest 300
[Re: cocobolo]
#2258861
02/24/17 05:33 PM
02/24/17 05:33 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Home Depot sells what appears to be an identical product for home duct use. The Fat Mat may be slightly thicker, but the idea is the same. Far less money. I tried some and it really does work. I have used the "duct" product with great results for around 80% less cost than fat mat....
