Re: Reverse flow cooling, worth it? [Re: an8sec70cuda] #2206499
12/02/16 02:11 PM
12/02/16 02:11 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
I plan to reverse cool my 540. I looked into putting anot air bleed in each head.
Re: Reverse flow cooling, worth it? [Re: an8sec70cuda] #2206510
12/02/16 02:39 PM
12/02/16 02:39 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I like the LS bleed lines in the corners of the heads frt/bk.I think people are scared to drill the port in the head.
Re: Reverse flow cooling, worth it? [Re: an8sec70cuda] #2206541
12/02/16 03:51 PM
12/02/16 03:51 PM
dogdays Offline
dogdays  Offline
I don't think it has much effect unless you build and tune the engine for it. The idea is to build more detonation resistance into the engine and then increase compression ratio and/or spark advance curve.
R.
Re: Reverse flow cooling, worth it? [Re: dogdays] #2206785
12/03/16 12:44 AM
12/03/16 12:44 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
There are plenty of vacuum coolant refill tools out there, costs are all over the place, but many under $100 usd. Makes it much easier to fill w/o air pockets. HTH, Steve
