Page 2 of 3 1 2 3
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2230829
01/09/17 03:03 PM
01/09/17 03:03 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Mine makes the exact same noise. Been doing for years.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2233936
01/14/17 10:37 AM
01/14/17 10:37 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Originally Posted By dodgedon
I would guess that a dealer would have to plug into the truck to "see" what the timing is doing while running?
I was fortunate this independent guy had good equipment, but even then he took it to another shop to confirm it.
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2429477
01/05/18 03:57 PM
01/05/18 03:57 PM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
Just wanted to give an update... This summer I had a dealer listen to the truck. He said the timing looked good. He was able to shut off an injector in each cylinder one at a time. He could produce the rattle noise on #2 and #9. He said he thought it was the flex plate rattling. Said it must be cracked...
Any thoughts on this?
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2429685
01/05/18 11:33 PM
01/05/18 11:33 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
How about possibly a timing chain rattling? Although they usually can rattle at idle, but being a 10 cyl, maybe they are in their own orbit on symptoms?
Re: 99 V10 engine noise...Bad cats?? [Re: buildanother] #2429919
01/06/18 02:09 PM
01/06/18 02:09 PM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
The tech never said anything about the timing chains on these engines. He didn't believe anything was wrong inside the engine. We both listened to the rattle and It does sound like its coming from the rear... I guess my question is how can i know for sure it is the flex plate? I took the cover off and cant see any cracks. He said it would crack around the crank bolts, And you cant see them from the bottom.
If I took the torque converter bolts out and pushed it back, could I run the engine to see if the noise is gone? Is there enough clearance for that?
67 Charger 383 auto
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2430396
01/07/18 09:19 AM
01/07/18 09:19 AM
Guitar Jones Offline
Pull the trans. If you were to run the engine disconnected from the torque converter you will gall the pilot hole in the crank and the converter hub and without any load on the flex plate it may not make any noise.
Re: 99 V10 engine noise...Bad cats?? [Re: Guitar Jones] #2430436
01/07/18 12:44 PM
01/07/18 12:44 PM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
Thank you, I figured there wouldn't be enough clearance. That's a lot of work to pull it back just to look but I don't have any other options do I? Being able to run it without load on the plate was the reason I wanted to try that.
If it is the flex plate the next problem is they are discontinued.... Is there any aftermarket options, or am i looking for a used one?
67 Charger 383 auto
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2430481
01/07/18 01:55 PM
01/07/18 01:55 PM
Try a google search you can probably find one on ebay.
Re: 99 V10 engine noise...Bad cats?? [Re: Guitar Jones] #2431084
01/08/18 03:22 PM
01/08/18 03:22 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My 96 V10 Ram has 168,000 on it now, the cats have been rattling for years. I just turn the radio up louder. LOL. One of these days I will just delete them. They do not seem to effect power or performance thus far.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 99 V10 engine noise...Bad cats?? [Re: 6PKRTSE] #2431120
01/08/18 04:13 PM
01/08/18 04:13 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
Get rid of the cats.probem solved
Re: 99 V10 engine noise...Bad cats?? [Re: d-150] #2431131
01/08/18 04:33 PM
01/08/18 04:33 PM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
IF you read this post from the beginning you will see that I did fix the exhaust. That was not the problem. A tech said he thinks its the flex plate. I'm looking for thoughts on this... As in are these flex plates know to crack? How Can I know for sure with out pulling back the trans? This truck only has 80,000 miles.
67 Charger 383 auto
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2431163
01/08/18 05:49 PM
01/08/18 05:49 PM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
Ok get it running .get under there with a piece of hose stick it to your ear.that should pinpoint your noise
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2431184
01/08/18 06:48 PM
01/08/18 06:48 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
IIRC you should be able to see a fair amount of the flexplate with the dust shield off the lower bellhousing.
Do a visual inspection and then do another check with it running to see if you can isolate the noise to the bellhousing area. twocents
Re: 99 V10 engine noise...Bad cats?? [Re: SNK-EYZ] #2431328
01/08/18 10:55 PM
01/08/18 10:55 PM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
I did do that earlier today. I had the cover off and ran it. It looks good but you can't see the center where the crank bolts are. I will admit its very loud with the cover off on start up, then the noise goes away.... I'm in the process of pulling the trans back. I will report what I find.
67 Charger 383 auto
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2433770
01/13/18 04:48 AM
01/13/18 04:48 AM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
Its not the flex plate. I think I found the problem though. I pulled the pan off and the rod bearings seem too loose... I will investigate more when I have time. Didn't expect that as it has really good oil pressure.
67 Charger 383 auto
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2433928
01/13/18 03:15 PM
01/13/18 03:15 PM
Alberta
440_Offroader Online content
440_Offroader  Online Content
Alberta
I thought it odd, that a tech would think it was a flex plate when the noise went away when dropping #2 or #9 cylinder. Wouldn't a flexplate make noise all the time the engine is running? I would investigate these 2 cylinders. Possibly loose bearing (like you suspect), wrist pin, or piston-cylinder clearances.
Re: 99 V10 engine noise...Bad cats?? [Re: 440_Offroader] #2434231
01/14/18 02:07 AM
01/14/18 02:07 AM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
It was actually just the opposite. No engine noise when at idle. He would shut off the cylinder and it would rattle. Turn it back on and the noise would stop. I did ask about wrist pins that day and he did agree that yes when an engine would come in knocking as they turned off the cylinder it would go away. He thought the engine just ran to smooth to be internal. He felt that as they turned off the cylinder the missing was shaking the crank and the possibly cracked flex plate.
I have been trying to figure out this rattle for like 4 years. I have asked here, other dealers and shops, everyone said it was exhaust rattling, nothing or normal sounds.. I drive trucks every day and just never believed this was normal "sounds". Never wanted to just start taking everything apart without knowing for sure what was wrong.
67 Charger 383 auto
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2434725
01/14/18 11:52 PM
01/14/18 11:52 PM
Nashport, OH
chargers777 Offline
chargers777  Offline
Nashport, OH
Have you checked your timing chain.I have the same problem and my chain is very loose at 85,000 miles.Had a gold star Chrysler mechanic with viper training check it and back me up on it.He says they used a poor quality chain from the factory without a tensioner.You can see it with the oil pan off.
Re: 99 V10 engine noise...Bad cats?? [Re: chargers777] #2434853
01/15/18 05:02 AM
01/15/18 05:02 AM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
I will look at it more this week. I didn't look to closely at the chain but I did see it when looking up from the bottom. Didn't notice anything unusual about it. But now is the time to be sure when its all apart.
67 Charger 383 auto
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2440646
01/25/18 05:28 PM
01/25/18 05:28 PM
Nashport, OH
chargers777 Offline
chargers777  Offline
Nashport, OH
Did you check the timing chain.I think the spec is 1/8 inch slop
Page 2 of 3 1 2 3
