Re: BB Cam bearing bore honing [Re: B5496RR] #2205958
12/01/16 05:30 PM
12/01/16 05:30 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Anything is possible. All Mike is doing with that hone is going in and opening up each individual cam bore to the proper size......that's easy. If the bore is not round or small, you hone it, not a big deal. Since cams have been in these motors before, you know the tunnel is relatively close and it's just an individual bearing that tight or out of round. This is NOTHING like line honing or line boring the entire cam tunnel. You do one of these two options to straighten or open up and entire cam tunnel. Doesn't matter that the bores are different size because when you line hone or line bore a cam tunnel, you open ALL the bores to a common size and have a custom cam ground. A common size is 50mm. That's big block Ford and bearings are common.
Re: BB Cam bearing bore honing [Re: madscientist] #2205968
12/01/16 05:45 PM
12/01/16 05:45 PM
Originally Posted By madscientist
That tool posted in the first post doesn't remove metal so I have no idea how MM is doing what they claim with that tool.
I have a Lisle precision cylinder hone like that hone, Sunnen makes one and I'm sure other good tool company make them and sell them also. I have removed over .0015 taper from more than one block with a torque plate mounted on them shruggy Their is a knob on the top of the hone to put pressure on the stones, the more pressure the quicker the cutting. Lisle and Sunnen offer different grit stones also up
I quit using mine long ago due to the time involved to get the job done compared to paying a good machine shop to do it on a commercial honing machine work shruggy
Re: BB Cam bearing bore honing [Re: Cab_Burge] #2205978
12/01/16 05:53 PM
12/01/16 05:53 PM
Washington
madscientist Offline
Washington
Guess I should have been more clear. I can't see the pic very well in the first post. I clicked on the link and looked at the hone in that link.
The hone they are showing in THAT picture is a monofilament BRUSH hone and will not remove much more than .0002 and you have to lean on it to make it do it.
I realize you can get roller cores with different bearings, but again, in the article, looks like they are using a FT cam. Didn't know you can get a core with different bearings for that.
Re: BB Cam bearing bore honing [Re: Cab_Burge] #2206727
12/02/16 11:42 PM
12/02/16 11:42 PM
USA
B5496RR Offline OP
B5496RR  Offline OP
USA
I have acquired a RIGID Lisle hone like the one I displayed in my original post.
As Cab Burge noted there is an adjustable nut to apply more force/pressure to the cutting stones.
The stones are 180 grit.
So far I have measured the #1 cam bearing bore in the block and it's .006 too small/under chrysler spec.
Can anyone give me a estimated time it would take to open this bore .006? 5 mins, 1 hour, 1 day of the drill motor turning the hone??
IS the block material softer than the cylinder bore material?
Re: BB Cam bearing bore honing [Re: B5496RR] #2206745
12/03/16 12:31 AM
12/03/16 12:31 AM
If you decide to hone the block make sure and use a spray on lubricant to help flush the metal out and keep the stones clean up I use a garden sprayer and a mix of diesel fuel(1 gallon) and 5W 20WT motor oil or 1 quart of ATF as the lube up
As far as how long on each cam journal it will depend on how much pressure and RPM your using on each journal work Make sure and use a good quality 1/2 inch electric drill motor, not a cheapo 3/8 size twocentsEDITED Make sure and stroke it front to back equally so you don't wear a groove into the stones, it would be easier if you had a way to control the stroke length and center the shaft to the hone so it doesn't wobble around a lot while honing work
Take your time on the first one, cut a little at a time and the measure again until you get it within .0005 on the small size and go from there thumbs
I'm thinking it will not go fast so be patient and take your time, good luck up
Re: BB Cam bearing bore honing [Re: B5496RR] #2206808
12/03/16 02:38 AM
12/03/16 02:38 AM
Canada
onig Offline
onig  Offline
Canada
How many guys use an old cam and cut slots in the bearing journal and run it through and spin it to remove material in the cam bearing?
69 Dart
Re: BB Cam bearing bore honing [Re: onig] #2206811
12/03/16 02:48 AM
12/03/16 02:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
ME... I do all my stock type bearings that way..
use oil and I spin it with my impact wrench...
the cam only turns 1/2 the engine rpm so mine
only turns 4100 cam rpms... I freshen the engine
but the cam bearings stay.. they look fine
wave
Re: BB Cam bearing bore honing [Re: B5496RR] #2206837
12/03/16 04:07 AM
12/03/16 04:07 AM
The block is cast, cured and machined as one piece, correct?
You will need to learn on how much preload to use on your hone by hands on testing the preload to make sure it is removing material and not polishing it work If it is not slowing the drill motor down under the load compared to unloaded it is probably polishing it instead of removing material scope
Another thing to check before you continue is the cam to make sure it is NOT bent scope
Been there, done that runaway Cast iron cores and steel billet cams can get bent, both can be straighten also by a good shop up
Don't we love trouble shooting whistling grin
Re: BB Cam bearing bore honing [Re: onig] #2207074
12/03/16 06:18 PM
12/03/16 06:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Me.
Re: BB Cam bearing bore honing [Re: B5496RR] #2207103
12/03/16 07:18 PM
12/03/16 07:18 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I have honed bb mopar cam housing bores before using a hone similar to the one pictured.
The biggest challenge in taking out as much as .006 will be preventing taper or bellmouthing the bore.
It won't take very much honing to do it. Exactly how long will depend on how much tension you put on the stones, rpm, and lube used.
Hone a little.... Check size and taper.... Hone some more, etc.
My understanding of how the factory did it was that there was a 5-step reamer used on the bearings themselves that did all 5 at one time, in place.
So it didn't matter if the factory cam tunnel bores were all that round or perfectly in line with each other....... Being sized in place, all at the same time made it less critical for that part of the block to be really "right".
I've actually gotten sort of burned by a screwed up cam tunnel on these motors before.
You have the block all done, then you go to install the cam bearings only to discover there is some issue with the cam tunnel.
Now, after the block comes out of the cleaner, it's the first thing I check.
Re: BB Cam bearing bore honing [Re: onig] #2207104
12/03/16 07:20 PM
12/03/16 07:20 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Lots of shops use "cutter cams" because it's quick, easy and usually works just fine. But to actually "fix" the issue......honing is the right way to do it.
As fast says, it will likely cut way faster than you think it will. Go slow, check it often
Re: BB Cam bearing bore honing [Re: B5496RR] #2207132
12/03/16 08:37 PM
12/03/16 08:37 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
The grooved cam trick has worked great for me.
Most of the tight ones I've found didn't need much. Only ever came across one that you almost couldn't push the cam into the bearings.
Re: BB Cam bearing bore honing [Re: B5496RR] #2207141
12/03/16 08:51 PM
12/03/16 08:51 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
on a tight cam bearing you are suppose to put the cam in the freezer and then install it. Just kidding.
Re: BB Cam bearing bore honing [Re: fast68plymouth] #2207170
12/03/16 09:19 PM
12/03/16 09:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The only CORRECT way to do it.
