Page 2 of 3 1 2 3
Re: BB DROP IN WATER PUMPS............... [Re: an8sec70cuda] #2205830
12/01/16 01:30 PM
12/01/16 01:30 PM
State of confusion
Thumperdart Offline OP
State of confusion
Forgot the wiring part...........I too wire mine directly into a relay then to a toggle on the dash.......... thumbs
Re: BB DROP IN WATER PUMPS............... [Re: an8sec70cuda] #2205834
12/01/16 01:37 PM
12/01/16 01:37 PM
MD-USA
Dodgeguy101 Online content
Dodgeguy101  Online Content
MD-USA
Originally Posted By an8sec70cuda
BradH...Like Bad340 said, no different than a mechanical pump going bad, you're screwed either way. My Meziere pump is almost 10 years old and has a ton of time on it...still working great.
We had a Weiand electric pump go bad on the Camaro last year...it still worked, but was making some awful grinding noises. Heard it when I got back to the trailer and shut the car off to let it cool. That pump had a lot of time on it too, although it was race only.
I may differ from a lot of folks, but I like everything wired on toggle switches. Just a normal relay and a toggle switch, flip it on once the motor is cranked and running clean. Then leave it on for a few minutes after I shut it off to cool it down good. That's REAL nice at the track as long as your battery is up to par.
Some may disagree, but I also have it wired with a relay, but it is wired so when I flip the fuel pump on, water pump comes on. Fuel pump is also on a relay in the back of the car. That way I dont forget to turn the water pump on. It is also wired so if I want to leave the pump on after I shut the engine off to cool the motor, I can manually turn the pump on.
Re: BB DROP IN WATER PUMPS............... [Re: Dodgeguy101] #2205837
12/01/16 01:43 PM
12/01/16 01:43 PM
an8sec70cuda Offline
I have toggle switches w/ little LED lights on them...red for fuel, blue for water pump, green for fan. Having the lights on them makes it easy to make sure they're on w/ a quick glance.
Just cheap ones from the parts store, but work great. Keep a couple spares in the toolbox just in case.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: BB DROP IN WATER PUMPS............... [Re: Bad340fish] #2206119
12/01/16 10:38 PM
12/01/16 10:38 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By Bad340fish
If they go bad its just like a mechanical pump going bad, your screwed lol
Yes, and no. When they break, they break. However, the auto parts store 100 miles from home can still get me a replacement belt-driven impeller assembly that can be swapped out so I can get back on the road. Not likely they're going to have quick availability to a replacement electric unit. So, do you carry all the hardware with you to swap back to a regular pump in this scenario?
Maybe they're a lot more reliable than I realize. But I hate being caught out when things like this happen.
It would be a quick way to free up about another 10 HP according to old tests I read, though.
Re: BB DROP IN WATER PUMPS............... [Re: BradH] #2206132
12/01/16 10:57 PM
12/01/16 10:57 PM
State of confusion
State of confusion
I've put a few 1000 miles on mine and over 10+ years solid service and I have AAA IF it happens..........try it Brad you'll like it.......... biggrin
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2206146
12/01/16 11:10 PM
12/01/16 11:10 PM
BradH Offline
BradH  Offline
What GPM would a legit drive-anywhere street car need? We don't get Vegas hot, but summers in the mid-to-high 90s are typical.
Re: BB DROP IN WATER PUMPS............... [Re: BradH] #2206150
12/01/16 11:12 PM
12/01/16 11:12 PM
State of confusion
State of confusion
Mine is only 28 gpm so the 35 and up would seem good enuff at our hp levels.............
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2206183
12/01/16 11:56 PM
12/01/16 11:56 PM
BradH Offline
BradH  Offline
All you folks running an electric water pump using an electric fan, too?
Re: BB DROP IN WATER PUMPS............... [Re: BradH] #2206187
12/01/16 11:58 PM
12/01/16 11:58 PM
State of confusion
State of confusion
All you folks running electric water pumps using an electric fan, too?
HHR elec. Bought from a member years ago but Rock Auto has em cheap I understand................
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2206205
12/02/16 12:16 AM
12/02/16 12:16 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I ran a Moroso belt style with the electric motor water pump on my Demon for 1000's of miles and never had a problem. I only had to turn the electric fan on when I was in city traffic. I upgraded to the ProForm electric pump on my D50. It works great also.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2206207
12/02/16 12:21 AM
12/02/16 12:21 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I have an electric fan that works quite well with the CVR in all weather *if* all systems are functional. It is triggered by a sending unit that grounds the relay at 175 degrees and runs until the engine gets back to 160.
If my hotrod dies on the road I'm calling a AAA/Hagerty flat bed or the wife to bring the CTD and car trailer. I called Baxter Auto parts (local parts shop) and confirmed that they can get a replacement over night if ordered by 5pm. We also get Summit from Nevada next day so it does not appear that the electric pump is much harder to get than a quality mechanical. It's not like you are going to put a Cardone rebuild on your 10k+ engine.
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2206246
12/02/16 01:17 AM
12/02/16 01:17 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I just switched to an electric pump, and haven't yet tested with it. I also built a fan shroud to move the fans off of the radiator for more flow.
I hope this helps as the engine was getting hot.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: BB DROP IN WATER PUMPS............... [Re: Hemi Allstate] #2206267
12/02/16 01:47 AM
12/02/16 01:47 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
The shroud is a great idea. I'll have to employee that over the winter. Car looks amazing btw!
Re: BB DROP IN WATER PUMPS............... [Re: Jeremiah] #2206278
12/02/16 02:02 AM
12/02/16 02:02 AM
Mt. Eden Ky.
Mt. Eden Ky.
Thanks !
I actually made the shroud by modifying a commercial cooking sheet. It is aluminum, and about 1.125" in height, which was just right for my needs.
1996 Ram 1500 Sport
1968 road runner
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2206332
12/02/16 03:54 AM
12/02/16 03:54 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You^^^^ might want to look into some Derale modules if that new setup doesnt work. Those fans you have dont look like real screamers. They need to move 2000cfm EACH to be worthy.
Mopar to the bone!!!
Re: BB DROP IN WATER PUMPS............... [Re: Thumperdart] #2206378
12/02/16 11:06 AM
12/02/16 11:06 AM
BradH...my Meziere is 42 GPM and does the job cooling my hemi. More is always better, so I'll be getting the bigger CVR pump when/if something happens to the Meziere.
I run the electric fan and shroud combo off of a 2003 dodge viper (P5007266). It's cheap w/ the employee discount at a dealership. It has a 2 speed fan, I just use the low speed. It fits my big 26" Griffin radiator real good. The radiator has 2 rows of 1.25" tubes and made a HUGE difference in cooling over my old stock replacement 26" copper radiator (bought it from Year One back in 1997).
CHIP
Re: BB DROP IN WATER PUMPS............... [Re: Hemi Allstate] #2206379
12/02/16 11:06 AM
12/02/16 11:06 AM
moparx Online content
moparx  Online Content
mark, glad to see you post again ! shroud looks good, and i hope it works out for you.
beer
Re: BB DROP IN WATER PUMPS............... [Re: 72Swinger] #2206403
12/02/16 12:07 PM
12/02/16 12:07 PM
Mt. Eden Ky.
Mt. Eden Ky.
I sure hope these fans will work, but I don't think they move 2,000 cfm. I bought them many years ago, and I don't remember the specs on them.
Thanks for the input.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: BB DROP IN WATER PUMPS............... [Re: moparx] #2206408
12/02/16 12:18 PM
12/02/16 12:18 PM
Mt. Eden Ky.
Mt. Eden Ky.
Hey Eric,
I am hoping with the new pump and shroud combo, it will help out. Especially between rounds .
Good to hear from you. beer
1996 Ram 1500 Sport
1968 road runner
Re: BB DROP IN WATER PUMPS............... [Re: Hemi Allstate] #2206435
12/02/16 01:29 PM
12/02/16 01:29 PM
State of confusion
State of confusion
Mark
I don't see those working well at all from personal experience and I'd pony up for the HHR which I heard blows 2800+............ thumbs
Page 2 of 3 1 2 3
