Page 2 of 45 1 2 3 4 44 45
Re: Trick Flow heads [Re: rickseeman] #1928328
10/08/15 01:19 PM
10/08/15 01:19 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Originally Posted By rickseeman
Since I don't know anything about a wedge why don't you guys enlighten me. Does this mean you use a bigger cam? I don't like rollers. Would a .590 lift purple shaft work well with these in a 512 BB? Thanks.
Purple shaft with stock stamped rockers are the HOT ticket right now.
Re: Trick Flow heads [Re: AndyF] #1928330
10/08/15 01:20 PM
10/08/15 01:20 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Originally Posted By AndyF
Originally Posted By BradH
Originally Posted By bubby440
I was planning on buying the std. port 440EZs for the 463 i'm putting together, but may now wait to see some more flow numbers on the Trick Flows.
Decisions, decisions shruggy
More flow tests won't change how the heads work; I'll be interested in how they perform on an engine.
I'll have dyno numbers in a few weeks.
Great Andy looking forward to it.
Getting old just means you were smarter than some and luckier than others.
Re: Trick Flow heads [Re: Streetwize] #1928337
10/08/15 01:37 PM
10/08/15 01:37 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By Streetwize
I think the only standard port head that tops these As-delivered were the old Chapman Stage VI 260 (which I think JohnRR sent to Dwayne the same time I sent my Chap 265 MW's) And the Chapmans were Raised ports and long valve heads that need special rocker gear. I think they went 360 up around .600-.650, may still be in the Moparts archives. Not sure they were any better than these at .400-.450 though.
I can provide some comparative data from Dwayne's current bench (a Saenz 600) tested on the same 4.375" bore:
A. My old PRH-ported MP Stage VIs w/ 2.14" intake valves and small 215 cc runners (w/o RB adapters added). On a 10.8:1 CR RB 452 short block using a modified MP M1 intake, my BG "825" carb, 2" headers and a 266 at .050" x .600" x 108 LSA SFT cam, it made around 610 HP & 570 Tq on Dwayne's dyno.
Lift -- Int / Exh (no flow tube)
.100 --- 69 / 53
.200 -- 143 / 108
.300 -- 213 / 146
.400 -- 262 / 181
.500 -- 293 / 211
.550 -- 305 / 222
.600 -- 307 / 231
.650 -- 307 / 237
.700 -- 307 / 243
B. My Hughes CNC-ported 1st-generation Edelbrock Victors w/ 2.20" intake valves and an estimated 270 cc runner volume (adjusted down about 40 cc for the built-in RB adapters). Like the Chapmans, these have raised ports and need special-offset intake rockers.
.100 --- 75 / 58
.200 -- 169 / 109
.300 -- 237 / 157
.400 -- 280 / 201
.500 -- 318 / 229
.550 -- 329 / 239
.600 -- 341 / 246
.650 -- 347 / 253
.700 -- 345 / 256
At the same CR as the MP Stage VIs and the .650" roller version of the SFT mentioned above, I'll take a s.w.a.g. and say I'd expect to see 640+ HP from the Trick Flows on the same RB 452 short block as the Stage VIs were tested, between the different heads and switching to a roller.
But it's all just educated(?) guesses until someone puts 'em in service. shruggy
Re: Trick Flow heads [Re: BradH] #1928340
10/08/15 01:41 PM
10/08/15 01:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By Thumperdart
I ported a set of rpm`s years ago on Pettis`s dyno that went 327-224 iirc...
Ummm... I think you mean flow bench, not dyno. grin
realcrazy My bad, too many blue moons..........
Re: Trick Flow heads [Re: BradH] #1928344
10/08/15 01:54 PM
10/08/15 01:54 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
Brad, didn't some combination of stuff we tried end up making like 625hp?
The CNC "standard" port Victors had quite a bit bigger port opening as I recall compared to a true std sized head.
These TF heads have port openings that look like a std valley pan gasket would seal up okay.
This particular set I have in the shop are going on a pump gas 505 with a solid cam and a 6bbl.
Re: Trick Flow heads [Re: fast68plymouth] #1928354
10/08/15 02:06 PM
10/08/15 02:06 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Here's the Chapman 260 standard Ports ( from the Tech archives)
These are the Chapman CNC'd MP Stage VI 260cc's:
Lift" I/E
.100--71.5/58.2
.200-150.0/118.6
.300-219.4/180.0
.400-278.7/219.4
.500-323.6/233.9
.550-338.9/240.3
.600-352.3/243.5
.650-348.5/246.7
.700-348.5/249.9
.750-348.5/251.5
.800-348.5/253.1
I think up to .450 the TW's are impressively close. 290cfm at only .450 is gonna be killer, you basically only need a very mild .525-.550 lift cam to easily cover 600hp, easy on the RPM/bottom end, easy on springs too
WIZE
In Car:
Re: Trick Flow heads [Re: fast68plymouth] #1928368
10/08/15 02:22 PM
10/08/15 02:22 PM
BradH Offline
BradH  Offline
Yeah, my ported Victor intake, a 1" open spacer and your CFS "dyno mule" Holley made about 625 HP. The 610 HP I referenced was as I ran it in my car (my carb & my ported M1 intake because of hood clearance), so I can correlate that to the car's on-track performance.
A modified Victor on the TFs w/ the .650" RX roller... 650+ HP? work (EDIT: The standard port location would even allow for running a Victor intake under my T/A hood grin )
Right; Hughes' "standard" CNC job still opens the entry to 2.40" x 1.30"; not MW, but definitely bigger than a standard valley tray port size. (EDIT: Found something that says the TF port entry is 2.270″ x 1.230... is this what you measured, too?)
Bet my ol' 440 6BBL RR would have loved that engine!
Re: Trick Flow heads [Re: BradH] #1928378
10/08/15 02:36 PM
10/08/15 02:36 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
I agree, but just want to see what the numbers may be after a little hand work. I'm wanting something in the 320-325cfm at .600".
72 Plymouth Roadrunner 11.08@123.25
Re: Trick Flow heads [Re: AndyF] #1928385
10/08/15 02:44 PM
10/08/15 02:44 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I hate to say this Andy but your DYNO numbers never show up in track times. Something in your corrections must be accrue. LOVE your products and use them but MOST dyno numbers are way out in left field almost as bad as the rag racing magazines. Hopefully track times will be posted early spring.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trick Flow heads [Re: pittsburghracer] #1928506
10/08/15 06:14 PM
10/08/15 06:14 PM
AndyF Offline
AndyF  Offline
You don't have a clue what you're talking about. The dyno that I use sends a lot of engines to the track and the track times back up the dyno numbers. You live a couple of thousand miles away from me and don't know anything about the dyno that I test on or the engine shop involved.
Re: Trick Flow heads [Re: fast68plymouth] #1928770
10/09/15 12:43 AM
10/09/15 12:43 AM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
Are the Trick Flows available w/stock straight plug design? Or are they all angled plugs? TTI headers in A-Body RB set up has a couple cylinders looking really close (visually) to accept angled w/out modifying.
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Trick Flow heads [Re: B Dartman] #1928774
10/09/15 12:45 AM
10/09/15 12:45 AM
Cab_Burge Online work
Cab_Burge  Online Work
Call Trick flow and let us know please scope thumbs
Re: Trick Flow heads [Re: Cab_Burge] #1928777
10/09/15 12:46 AM
10/09/15 12:46 AM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
LOL - Yup, was going to call Friday
Re: Trick Flow heads [Re: B Dartman] #1928879
10/09/15 10:01 AM
10/09/15 10:01 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Uh oh!
Bill stepping it up a notch... grin
Re: Trick Flow heads [Re: fast68plymouth] #1928904
10/09/15 10:57 AM
10/09/15 10:57 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Someone needs to remake the Chapman heads. smile
Re: Trick Flow heads [Re: B Dartman] #1928920
10/09/15 11:28 AM
10/09/15 11:28 AM
BradH Offline
BradH  Offline
I'd say to expect they're ALL angle-plug because it goes w/ how the chamber was designed.
Re: Trick Flow heads [Re: 70VcodeCoronetRT] #1928924
10/09/15 11:32 AM
10/09/15 11:32 AM
BradH Offline
BradH  Offline
You mean that still need RB adapters and sell for $2500+ each bare? I don't think so... They really missed the market for those.
Edelbrock could have nailed it w/ the Victors, only they didn't get it "right" either. At least you can still buy Victors and they priced them reasonably.
Re: Trick Flow heads [Re: Roughbird72] #1928931
10/09/15 11:48 AM
10/09/15 11:48 AM
BradH Offline
BradH  Offline
According to Trick Flow, they already are. wink
Re: Trick Flow heads [Re: BradH] #1928951
10/09/15 12:17 PM
10/09/15 12:17 PM
Roughbird72 Offline
Roughbird72  Offline
Re: Trick Flow heads [Re: fast68plymouth] #1929705
10/10/15 05:40 PM
10/10/15 05:40 PM
So. Burlington, Vt.
So. Burlington, Vt.
It seems every time a new product comes on the market there is always something about it that makes you scratch your head..... Like these harmless looking little squares cast into the decks of these new TF heads
