Page 2 of 3 1 2 3
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2202377
11/25/16 03:06 PM
11/25/16 03:06 PM
A727Tflite Offline
A727Tflite  Offline
Hey there Mr. P - I am agreeing with you - .040" is way out - the point of my post is you would think a "shop" doing this kind of work would follow some basic guidelines for runout. Was wondering if they ever made it right? Just wondering.
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: A727Tflite] #2202423
11/25/16 04:31 PM
11/25/16 04:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I took it back but they said I MUST have done something
to it to be out like that.. I told them I pulled it out
and turned it 180 then tried it again... was still bad
but they didnt want to give my money back..it had a total
of 3 passes on it
wave
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: MR_P_BODY] #2202520
11/25/16 07:22 PM
11/25/16 07:22 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
but they didnt want to give my money back...
So, which shop is this that sells nonrefundable banana-shaped shafts? boogie
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: MR_P_BODY] #2202526
11/25/16 07:29 PM
11/25/16 07:29 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Mr P if interested in salvaging the shaft call a local marina service shop and ask where they take shafts that need straightening. Boat prop shafts are always getting bent.
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: DrCharles] #2202542
11/25/16 08:02 PM
11/25/16 08:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I forget which shop it was and I dont want to bad
mouth the wrong shop but it was one of the more well
known places.. this was about 20 years ago when I
built my Valiant
wave
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: mopardamo] #2202544
11/25/16 08:05 PM
11/25/16 08:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I took off all the parts and trashed the tube.. but I
know what your saying about the marinas getting solid
shafts straightened .. I had my old boats shaft done
wave
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2202802
11/26/16 12:43 PM
11/26/16 12:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Got any driveline company's in your city?
We have several and I deal with a couple of them since I own a fleet of trucks. I had one built for BB E body over 10 years ago. It runs smooth to over 100 MPH and was very reasonable in cost.
This is coming from someone who has bought a ton of Mark Williams products over the years. IMO shipping is too high for something common like a drive shaft that can be made local for a door car. Yes even for a "race" car.
Yup I weighed it and it weighed less than my steel driveshaft.
I went from a 8.75 rear to a dana rear and needed it an inch longer I think? Took my old shaft down there to the local driveline shop and said I want it an inch longer and they got it right the first time. I know them also so why not support the local guy?
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: Challenger 1] #2202805
11/26/16 12:57 PM
11/26/16 12:57 PM
moparx Offline
moparx  Offline
i always support the local guy when possible. but with that said, make sure your local shop can balance the shaft at more than 1000rpm. the truck places around here only have low rpm balance. when you combine deep gears and overdrive, your drive shaft is turning considerable rpm at 70+ highway speed, and even more at the track without overdrive in the picture. a truck shop probably isn't the place to consider obtaining a shaft from. i've run into this too many times to not think in this manner.
beer
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: moparx] #2202808
11/26/16 01:08 PM
11/26/16 01:08 PM
Cincinnati, Ohio
Cincinnati, Ohio
beer
I don't buy this, my trucks have 6:13 and 5:38 gears in them...The truck driveline shops can balance your driveshaft. They do all driveline work, not just trucks.
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: Challenger 1] #2202819
11/26/16 01:32 PM
11/26/16 01:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes they have steep gears but also have BIG tires
for the loads... they dont turn that many rpms and
it seems that trucks shops dont care if there is a
bit of vibration since they have a lot of vibrations
wave
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2202820
11/26/16 01:34 PM
11/26/16 01:34 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I noticed that some places like PST will SFI certify a shaft. When is this necessary? Is there a know amount of weight savings from a stock driveshaft to a C/M shaft to an aluminum shaft? normal length, approx. 52". Mine was built so long ago, I don't even know what material it was built from. Local shop where I worked did it. Just trying to decide if an upgrade is worth it. Aluminum doesn't seem to be able to handle to power levels of C/M. I need to weigh mine, later, for comparison to anyone else.
[image][/image]
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2202857
11/26/16 03:09 PM
11/26/16 03:09 PM
New York
polyspheric Offline
polyspheric  Offline
New York
CM is much stronger than 6061.
AL weight savings is only a tiny bit more than the actual difference (in lbs.) even though it's rotating weight, because the mass center of rotation is so small.
Remember: O/D doesn't slow down the driveshaft speed, only the engine speed, the shaft still runs at the rear axle ratio.
Boffin Emeritus
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2202870
11/26/16 03:41 PM
11/26/16 03:41 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Action Machine, best for the money.
Mopar to the bone!!!
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: MR_P_BODY] #2202900
11/26/16 05:05 PM
11/26/16 05:05 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Who was the company who built the bad shaft Mike? Was it Cameron's Cove?
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2202909
11/26/16 05:21 PM
11/26/16 05:21 PM
sgcuda Offline
sgcuda  Offline
My u joint center to center is 42 1/2". Fitted with 1350 joints and a Mark Williams slip yoke. It weighs 21 pounds. Can anyone tell by the weight if this is just old school steel or thinwall C/M? Do I need to upgrade my driveshaft for an 8 second car?
[image][/image]
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: HardcoreB] #2202914
11/26/16 05:34 PM
11/26/16 05:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As I said before.. I dont recall.. too many years
now... but it was not the one you named
wave
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2202936
11/26/16 06:31 PM
11/26/16 06:31 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
I'm getting ready to order a driveshaft for my 68 cuda. Being that i'm starting from scratch, what would you guys get, Aluminum or steel? 950 hp 850 tq. street car with a 4 speed. maybe around 3300 lbs. I would like the aluminum for weight savings, if it would be strong enough...
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: Old School] #2202939
11/26/16 06:40 PM
11/26/16 06:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Myself I would go with steel on the street.. I
called Dynotech to see what I should go with..
they said DOM so I did with good U-joints and
yokes
wave
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: 1964superstock] #2202964
11/26/16 07:39 PM
11/26/16 07:39 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Why aluminum?
Anyone do back to back test?
Re: Aluminum Driveshaft, who is the best for the $$$??? [Re: nss guy] #2202983
11/26/16 08:41 PM
11/26/16 08:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By nss guy
Why aluminum?
Pretty pricey back to back test
wave
Page 2 of 3 1 2 3
