Re: Master Cylinders: Bench Bleed or just mount and bleed ? [Re: Kern Dog] #2203779
11/28/16 09:10 AM
11/28/16 09:10 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
It seems the most significant advantage to bench bleeding is you can do it without any assistance. I'm used to working by myself so that's the method I prefer. Here's a kit to accommodate bench bleeding:
http://www.oreillyauto.com/site/c/detail/MTM0/13911/N0678.oap
Here's a video showing how it's done:
https://www.youtube.com/watch?v=kEPXgDGU6_0
No mess, no help needed.
Re: Master Cylinders: Bench Bleed or just mount and bleed ? [Re: Supercuda] #2203780
11/28/16 09:27 AM
11/28/16 09:27 AM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
Originally Posted By Supercuda
I have two steel lines that fit the outlets, bend them around to dump into the reservoir. Install M/C, put on bleed lines, put in fluid, slowly work pedal to "bench bleed", remove bleed lines one at a time, installing regular brakes lines and wheel bleed from there.
Same here, plus I also save all the fittings and little flex hoses they give you with a new/reman master cylinder.
Karma has no menu. You get served what you deserve.
Re: Master Cylinders: Bench Bleed or just mount and bleed ? [Re: Kern Dog] #2203812
11/28/16 11:59 AM
11/28/16 11:59 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Just go n buy a Cardone Master Cyl.bench bleeder #10-5000MCB n GIT R DONE,I believe the GM master cyl.angle is for directing the energy from a collision upward so the pedal goes down away from the drivers legs.
