Re: Duster front spoiler
[Re: SpareParts]
#2200356
11/22/16 01:28 AM
11/22/16 01:28 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I made myself...junkyard score late 80s Ford Ranger.. I had to stretch it in the middle 8 inches
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2200360
11/22/16 01:30 AM
11/22/16 01:30 AM
WHITEDART
bean town ....Ca
Side view... it hangs down 4 inches.. and is matte black... most people didn't notice that I had put it on.. and it hasn't proven to be quicker yet
[Re: SpareParts]
#2200396
11/22/16 02:21 AM
11/22/16 02:21 AM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Kinda harder to see in this one. Well since I apparently can't own it can you pm me or post the dimensions of it... or your address and you'll see my truck and trailer soon I will try to get you some better pictures and measurements tomorrow
[Re: SpareParts]
#2200451
11/22/16 11:37 AM
11/22/16 11:37 AM
Posts: 782 s.e. MI
partsforsale
s.e. MI
If the idea is to keep air out from under the rear of the car (causes lift), install a V-patterned piece of sheet metal/plastic that hangs a few inches down from rocker panels in front of rear tires with the tip of the "V" around the trans tail shaft.
For reference, look at the aero skirts on a semi-truck trailer that hang down from the center front of the trailer and expand outward toward the tires at the back of the trailer.
[Re: SpareParts]
#2200490
11/22/16 01:37 PM
11/22/16 01:37 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Aren't you a tin knocker? Make one your self!!
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: SpareParts]
#2200894
11/22/16 11:55 PM
11/22/16 11:55 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks! I appreciate that. What's it made out of? Fiberglass. sorry it took so long. My pictures are to big for the site and Photobucket isn't loading tonight. I will try later but it measures 63 inches end to end at the top and 56 inches at the bottom. The drop is 5 inches on the ends and 4 inches in the middle.
