Re: TIRED OF BEING SLOOOOOWWWWW.....................
[Re: Thumperdart]
#2199170
11/19/16 11:22 PM
11/19/16 11:22 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
BOOST Dom,,,,,,,,,,,BOOST ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif)
[Re: Thumperdart]
#2199209
11/20/16 12:57 AM
11/20/16 12:57 AM
Posts: 1,030 ohio
67mprfan
ohio
Maybe your carb just needs a few tweaks.... No doubt........ ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) Bored w/my car plain and simple X2
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: Thumperdart]
#2199279
11/20/16 08:23 AM
11/20/16 08:23 AM
Posts: 2,578 sweden
1Fast340
sweden
All in fun and I would grab it in second and hang on............NO desire to get crazy(er) and become a full time nos guy but want the "just in case" the need arises and the 8 3/4 would spit it's guts out or at least that`s what I read/heard.......... [/quote] And all of a sudden that need will arise more and more often and you will need a bigger fix each time to satisfy your needs,sounds like an awsome plan ![panic panic](/ubbthreads/images/graemlins/custom/panic.gif)
[Re: Thumperdart]
#2199320
11/20/16 12:14 PM
11/20/16 12:14 PM
Posts: 10,031 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Be careful Dom. Its addictive! Maybe you should invest in some run flats, in case you drive over the crankshaft ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) seriously, maybe a low boost turbo would serve you better. I believe they have somewhat lower cylinder pressure for the horsepower generated. You might be able to get away with just the turbo, no intercooler with limited boost. It would still make great power.
[Re: Thumperdart]
#2199323
11/20/16 12:18 PM
11/20/16 12:18 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
My ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Why not put the money you would spend on spray into a cage upgrade? Then you can run the car out every pass. It would be good to see the car at the track more often.
"Just a Bracket car dressed up like a streetcar"
[Re: Thumperdart]
#2199349
11/20/16 01:38 PM
11/20/16 01:38 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Buck-fifty on a 470? Child's play... bring it in as soon as the front tires set down, and shift to second immediately, then shift to third about 500 rpm early. Have the two hundred jets ready when you get back to the pits.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: Thumperdart]
#2199408
11/20/16 03:52 PM
11/20/16 03:52 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
What the heck is a NOS puck system ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) This is the first time I have heard that term
[Re: Cab_Burge]
#2199415
11/20/16 04:04 PM
11/20/16 04:04 PM
Thumperdart
State of confusion
It`s a round puck that mounts to the bottom of the plenum and sprays directly into the intake ports on the floors..........
