Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199170
11/19/16 11:22 PM
11/19/16 11:22 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
BOOST Dom,,,,,,,,,,,BOOST stirthepot
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199209
11/20/16 12:57 AM
11/20/16 12:57 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Originally Posted By Thumperdart
Originally Posted By Adobedude
Maybe your carb just needs a few tweaks....
No doubt........ biggrin Bored w/my car plain and simple
X2
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199233
11/20/16 01:44 AM
11/20/16 01:44 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Your car is not slow Dom, just not as quick as you would like it to be.
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199250
11/20/16 02:56 AM
11/20/16 02:56 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Too funny...........My motor will probably laugh at a 150 hit but I want a good 1/8th pass just to see a 5-second slip and to feel the rrruuussshhhhhhhhhhhhhhh............... biggrin
Your running so Close to a 5 sec, 1/8th now. IMO, do it NA first, then add the juice. Why cheat, when you are oh so close. tsk beer up
Lose a few more pounds, shave the heads, advance the cam abity, and your there. up
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199261
11/20/16 03:47 AM
11/20/16 03:47 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Be happy with what you have, don't mess with success. That car rips as is.
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199264
11/20/16 04:14 AM
11/20/16 04:14 AM
'murica
misfired Offline
misfired  Offline
'murica
Why stop @ 150? Let it eat, I mean why aim for a 5.9xx when you can go 5.5x?? Just sayin, you have a great start imo looking forward to results!
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: misfired] #2199265
11/20/16 04:27 AM
11/20/16 04:27 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The 8.75 maybe. tsk beer
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199268
11/20/16 05:03 AM
11/20/16 05:03 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Why spray a car that already runs good?.........Simple answer is because it runs better. Just got back from the track helping a customer. 2900lb Mustang on 29.5s with a 370" small block. Ran some nice easy 5 teens
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199279
11/20/16 08:23 AM
11/20/16 08:23 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
All in fun and I would grab it in second and hang on............NO desire to get crazy(er) and become a full time nos guy but want the "just in case" the need arises and the 8 3/4 would spit it's guts out or at least that`s what I read/heard.......... biggrin
[/quote]
And all of a sudden that need will arise more and more often and you will need a bigger fix each time to satisfy your needs,sounds like an awsome plan panic
laugh
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199307
11/20/16 11:49 AM
11/20/16 11:49 AM
Mo.
racerx Offline
racerx  Offline
Mo.
iagree ....Dom's car runs very well smoke how much nos can he spray when his car if it's setup naturally aspirated before he will have to start changing stuff like cams,converters,etc.
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199320
11/20/16 12:14 PM
11/20/16 12:14 PM
gregsdart Offline
gregsdart  Offline
Be careful Dom. Its addictive! Maybe you should invest in some run flats, in case you drive over the crankshaft smile
seriously, maybe a low boost turbo would serve you better. I believe they have somewhat lower cylinder pressure for the horsepower generated. You might be able to get away with just the turbo, no intercooler with limited boost. It would still make great power.
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199323
11/20/16 12:18 PM
11/20/16 12:18 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
My twocents Why not put the money you would spend on spray into a cage upgrade?
Then you can run the car out every pass. It would be good to see the car at the track more often.
"Just a Bracket car dressed up like a streetcar"
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199349
11/20/16 01:38 PM
11/20/16 01:38 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Buck-fifty on a 470? Child's play... bring it in as soon as the front tires set down, and shift to second immediately, then shift to third about 500 rpm early. Have the two hundred jets ready when you get back to the pits.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: MoparBilly] #2199370
11/20/16 02:45 PM
11/20/16 02:45 PM
State of confusion
Thumperdart Offline OP
State of confusion
Damn, you boyz are serious about this stuff and I love it........... biggrin Did some street testing yesterday w/my old faithful VP-101 and pump mix and got a bad vibration above 6500 in 2nd so I`ll fix that( luck) and head to Irwindale the following thu after Thanksgiving and go from there and I appreciate the comments thankxxx. No boost or turbos hanging in my engine bay ever and this is more less to see if nos is something I`d be willing to build my next motor for that`s all..........more FUN than serious but last time I said that, I was beaten, cuffed and sent to the fun house............ laugh2 realcrazy
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199373
11/20/16 02:54 PM
11/20/16 02:54 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
you know those turbos and prochargers are easier on parts than spray. I'm building my 511 with future procharger or turbo in mind.
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: mopar dave] #2199379
11/20/16 03:07 PM
11/20/16 03:07 PM
State of confusion
State of confusion
Yep, and monkey see monkey do to me cos damn near every car runs em these days so no desire there. I`m a fickle [censored] so after a couple of weeks we'll see...........Keep it the same, add nos, sell it who knows............ shruggy
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199385
11/20/16 03:20 PM
11/20/16 03:20 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
yeah, I understand. spray would be a more affordable path to big power in the short run, but I have friends that spray and work on their engines all the time too. in the long run I think boost is the way.
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: mopar dave] #2199386
11/20/16 03:23 PM
11/20/16 03:23 PM
State of confusion
State of confusion
Whatever works for each of us but I'M DAMN BORED.............. devil
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Thumperdart] #2199408
11/20/16 03:52 PM
11/20/16 03:52 PM
What the heck is a NOS puck system confused This is the first time I have heard that term shruggy
Re: TIRED OF BEING SLOOOOOWWWWW..................... [Re: Cab_Burge] #2199415
11/20/16 04:04 PM
11/20/16 04:04 PM
State of confusion
State of confusion
It`s a round puck that mounts to the bottom of the plenum and sprays directly into the intake ports on the floors..........
