Re: Demon build
[Re: Quickrunner]
#2205153
11/30/16 11:55 AM
11/30/16 11:55 AM
Posts: 625 Indianapolis In. usa
Quickrunner
Thanks for comments guys. I got the car home last night and could not be happier with the job Gary did on the cage. He was able to execute every little subtlety that I requested on it. The tin in the back will not need to be removable so plan is paint or powdercoat then they will be riveted in after cage is painted. The pictures really don't do it justice, the dash bar between the A pillar bars is a work of art. I can still drop column if needed and remove dash if needed and there is still room for the small vintage air unit and the hidden wiper motor. Glove box door is still functional minus the cardboard box, that will make a nice location for a panel to mount the Dominator EFI.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Demon build
[Re: Quickrunner]
#2205305
11/30/16 04:30 PM
11/30/16 04:30 PM
Posts: 19,366 Las Vegas
Al_Alguire
Las Vegas
Looks awesome..Cant wait to see the finished product.
Re: Demon build
[Re: Quickrunner]
#2209264
12/07/16 12:36 PM
12/07/16 12:36 PM
Quickrunner
Had to machine .200 off bottom or rack mounting pad and bracket to get rack to clear new pan. Fits nice now with little over .150 clearance and since solid mount it will work fine.
Re: Demon build
[Re: Quickrunner]
#2209395
12/07/16 04:20 PM
12/07/16 04:20 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
May want to space tierods down same amount.
Mopar to the bone!!!
Re: Demon build
[Re: 72Swinger]
#2209464
12/07/16 06:10 PM
12/07/16 06:10 PM
Quickrunner
May want to space tierods down same amount. I did, but final tweeks will be done on alignment rack when car is all done and at final ride height and full of fluids and me in it.
Re: Demon build
[Re: Quickrunner]
#2209532
12/07/16 08:07 PM
12/07/16 08:07 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Dave will you be able to drop the oil pan if needed? I'm guessing you'd just have to un-bolt the rack and slide it forward.
Re: Demon build
[Re: ProSport]
#2209667
12/07/16 10:52 PM
12/07/16 10:52 PM
Quickrunner
Dave will you be able to drop the oil pan if needed? I'm guessing you'd just have to un-bolt the rack and slide it forward. Hope to never need to drop the pan! LOL but yeah, just unbolt rack and pan will come right off.
Re: Demon build
[Re: Quickrunner]
#2266711
03/10/17 12:27 PM
03/10/17 12:27 PM
Quickrunner
Picked up the seat I have been looking for at the Indy swap meet. Its 67 barracuda so I am gonna have Legendary do up a cover in the correct 71 blue but in this pattern. I really wanted the bench with fold down armrest after seeing Jody's car. Need to cut out kidney bar and redo it with about half inch more clearance but the rest is all good, clears hoop and everything else by 1/4 inch
Re: Demon build
[Re: Quickrunner]
#2266714
03/10/17 12:33 PM
03/10/17 12:33 PM
Quickrunner
Also made a pretty big order with Summit yesterday. Reid racing sfi turbo 400 transmission case and gen 3 bell housing for it! So now I can fab cross member and finish any floor mods to clear trans and gear vendor unit if needed. Excited to get the ball rolling again.
Re: Demon build
[Re: Quickrunner]
#2268547
03/13/17 12:31 PM
03/13/17 12:31 PM
Quickrunner
Reid case and B&M pan showed up, bell should be here Wednesday. Cut stock T bar/trans cross member out flush to framerails and plated it off. Going to fab tubular bolt in trans Xmember when bell gets here.
Re: Demon build
[Re: Quickrunner]
#2269848
03/15/17 10:24 AM
03/15/17 10:24 AM
Quickrunner
The bell showed up! This thing is nice and beefy. I also started fabing up the bolt in trans cross member.
Re: Demon build
[Re: Quickrunner]
#2269864
03/15/17 11:02 AM
03/15/17 11:02 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
Any issues with floor clearance and the 400?
68 Barracuda Formula S 340
Re: Demon build
[Re: Quickrunner]
#2269872
03/15/17 11:13 AM
03/15/17 11:13 AM
Quickrunner
I had already removed the pinch weld when I redid the fire wall so that was fine but the Reid case had one high spot that required a 2 inch long by about 1/2 inch deep dent on passenger side of tunnel close to the top. If you look at the pic of the trans its the boss just to the left of the "REID" letters that 's what hit. That may not exist on a stock 400 case I really don't know.
Re: Demon build
[Re: Quickrunner]
#2271203
03/17/17 03:19 PM
03/17/17 03:19 PM
Quickrunner
Nut plates welded into frame rails and cross member tacked up ready to be finish welded.
