Re: Finally ran our 392 Gen 3 Hemi today...
[Re: Brian Hafliger]
#2206489
12/02/16 02:58 PM
12/02/16 02:58 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
Man, those are some fantastic numbers! Been along time since ive done anything with cars....these Gen III Hemis seem to be the next big thing. Fantastic job Brian!
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: PUNK]
#2206524
12/02/16 04:02 PM
12/02/16 04:02 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Man, those are some fantastic numbers! Been along time since ive done anything with cars....these Gen III Hemis seem to be the next big thing. Fantastic job Brian! Thank you Brian/Doug! Not sure which one...LOL!!
Brian Hafliger
#2207602
12/04/16 03:28 PM
12/04/16 03:28 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Did you say RX 7 as in Mazda? Oh my, that should be interesting...
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: mopardamo]
#2208365
12/05/16 09:48 PM
12/05/16 09:48 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Wondering how much it is to duplicate that power plant? Give me a call anytime...
Brian Hafliger
#2383999
10/08/17 05:32 PM
10/08/17 05:32 PM
Posts: 12,396 Taxes & Virus's R-US, NY
Dragula
We made 695HP and 530TQ with it...6.4 heads, 12.5:1, custom IMM cam, stock rockers and lifters...used a 1050 and drag pak intake. It was fun using the MSD and no leaks!! Really neat sounding engine, very quiet even at 7500rpm. https://youtu.be/m2z18MC7hbgVery interested in a build like this...how much cam, hydraulic or mech? And was the 1050 on E85?
#2384566
10/09/17 05:49 PM
10/09/17 05:49 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
what is the crankshaft stroke and cyl bore? is it the conventional 392" specs.? will a stock 392 bottom end do the job or do you have to upgrade. i assume pistons and rings are something special at least?
is this a non mds cam or did you modify it for your cam? i have a 2012 5.7 from a 2500 truck with 80k miles. i understand its not an mds cam. do you know if this block is different for the non MDS cam? i grabbed it because its not mds. do you have an opinion?
sorry ive did not see the build specs or build post on this motor. but it looks simple and reliable..and for that kind of power.. its got me motivated .. thats plenty for my needs. jim
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#2385092
10/10/17 02:20 PM
10/10/17 02:20 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
sorry ive did not see the build specs or build post on this motor. but it looks simple and reliable..and for that kind of power.. its got me motivated .. thats plenty for my needs. jim Your block is the same as all the other 2009 to 2017 5.7 blocks no matter or not they have MDS. It is a VVT engine, all the 09+ have VVT. You have nearly the best heads. I have torn apart quite a few with 300,000 miles and they show almost no bore wear and the bearings look even better.
