Re: Billet valve covers
[Re: Ari440]
#2976822
10/21/21 01:30 PM
10/21/21 01:30 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
ANDY
can you make valve cover spacers 1/2 for B1 heads ? Does anyone on here know who makes B1 valve covers (cast or fabricated) that fit with out welding and grinding for the distributor curves? I've tried calling Jeff Johnson at Billet fabrications with no response so far
[Re: Cab_Burge]
#2976988
10/21/21 08:52 PM
10/21/21 08:52 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Initially I had both style sets of B1 cast design valve covers, and ended up using custom fabricated valve covers on my B1 Original head motor. The fabricated covers were made by a vendor Best Machine was using at the time, but I don't remember the name. They were quality valve covers. Call Chuck at Best Machine for fabricated valve covers, I'm sure he can get you taken care of, or Koffel's Place or Brodix direct for the B1 logo cast valve covers, or Indy for their smooth surface (no Indy logo) cast big block valve covers. Depending on which distributor and rocker system you're using, might require slight modification to the valve covers. I also ran an offset distributor.
All the aforementioned will fit B1 BS, B1 Original, B1 MC, Indy, and factory stock Mopar cast iron big block heads.
The billet covers Andy is showing here look sweet also!
Wes
"Any fool can know. The point is to understand"
- A. Einstein
[Re: Cab_Burge]
#2977090
10/22/21 02:04 AM
10/22/21 02:04 AM
Posts: 610 Boise
Moparteacher
Boise
ANDY
can you make valve cover spacers 1/2 for B1 heads ? Does anyone on here know who makes B1 valve covers (cast or fabricated) that fit with out welding and grinding for the distributor curves? I've tried calling Jeff Johnson at Billet fabrications with no response so far Have you contacted Doug Lee of PrpPan in Oklahoma? http://propan.net/
[Re: Moparteacher]
#2977223
10/22/21 12:33 PM
10/22/21 12:33 PM
Cab_Burge
ANDY
can you make valve cover spacers 1/2 for B1 heads ? Does anyone on here know who makes B1 valve covers (cast or fabricated) that fit with out welding and grinding for the distributor curves? I've tried calling Jeff Johnson at Billet fabrications with no response so far Have you contacted Doug Lee of PrpPan in Oklahoma? http://propan.net/ I just got of the phone to them, thanks I don't know yet if they make them or not, the shop is busy and the owner is suppose to call me back
[Re: Cab_Burge]
#2977259
10/22/21 02:06 PM
10/22/21 02:06 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
Williams Performance or Winchester Metal works?!?
[Re: mopardude318]
#2977960
10/24/21 07:22 PM
10/24/21 07:22 PM
Posts: 6,145 Melbourne , Australia
LA360
ANDY
can you make valve cover spacers 1/2 for B1 heads ? I can LA360, can you make a set for a small block? I have Trick Flow heads. Sorry I missed this post. I will make some for one of my own engines at some point, but not any time soon. Too busy with my 9-5 job and have a couple of other projects on the go at the moment. When I do, I will probably make a few pairs.
Alan Jones
