Page 43 of 45 1 2 41 42 43 44 45
Re: Trick Flow heads [Re: fast68plymouth] #2178064
10/18/16 08:54 PM
10/18/16 08:54 PM
AndyF Offline
AndyF  Offline
Flow numbers on the 270 head are floating around, there is a brochure from Trick Flow that I've seen. 350cfm @ .700 lift is what I recall on the intake side. Exhaust flow didn't change.
Re: Trick Flow heads [Re: AndyF] #2178177
10/18/16 10:55 PM
10/18/16 10:55 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
I'm safe then. I wont make 600 horse after the head exchange. I'm at like 530-540 currently.
Re: Trick Flow heads [Re: fast68plymouth] #2178637
10/19/16 03:28 PM
10/19/16 03:28 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
The 270 looks like it might be a good head for my Procharger BB build. HMMMMM
Re: Trick Flow heads [Re: fast68plymouth] #2191595
11/07/16 04:50 PM
11/07/16 04:50 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
AndyF, you ever use a strobe or timing light on the valve train while it's running with the clear valve covers?
Re: Trick Flow heads [Re: fast68plymouth] #2192292
11/08/16 06:03 PM
11/08/16 06:03 PM
AndyF Offline
AndyF  Offline
No, I don't have the right equipment to do that. I can shoot video with my iPhone and then do slow motion but I haven't tried it yet. My guess is that the iPhone can't slow down enough to see anything but I could be wrong.
Re: Trick Flow heads [Re: fast68plymouth] #2192349
11/08/16 08:01 PM
11/08/16 08:01 PM
AndyF Offline
AndyF  Offline
Trick Flow has their 2017 catalog on their website. It has the 270 heads in it as well as a new valley plate. I don't think you can order any of the parts yet though.
Re: Trick Flow heads [Re: fast68plymouth] #2192530
11/09/16 12:14 AM
11/09/16 12:14 AM
AndyF Offline
AndyF  Offline
Here is a link to the Car Craft article: http://www.hotrod.com/articles/trying-find-extra-power-rocker-arm-testing/
Has some embedded videos so the link might be slow due to the ads.
Re: Trick Flow heads [Re: fast68plymouth] #2192558
11/09/16 12:47 AM
11/09/16 12:47 AM
Utah, USA
1964superstock Offline
Utah, USA
Congrats Andy! Awesome, great article and videos for Hot Rod magazine. Very cool to get the info here first on Moparts. Love those RAS rocker arms, glad I have a set. Any hopes of those being produced again?
Re: Trick Flow heads [Re: AndyF] #2193570
11/09/16 11:26 PM
11/09/16 11:26 PM
Seattle, WA
3
375inStroke Offline
375inStroke  Offline
3
Seattle, WA
The strobe does the work. Just turn the room lights down. Easiest way is using a timing light since it will be synced to the motor, so it will fire at the exact same time every revolution. It'll look like the valves aren't moving, but you will be able to see anomalies like spring oscillation, or various parts deflecting. You'll also be able to video it with just a regular cell phone at normal speed since it will only pick up the split second the timing light fires. If the timing light has that dial on it, you can delay the firing of the light to see the rocker at different amounts of lift. Just think of what the damper looks like when you're setting the timing. I don't know how long you can keep the motor at high revs, but just try it at idle and I think you'll be intrigued. Of course seeing a video with the clear covers would be great, too.
Re: Trick Flow heads [Re: fast68plymouth] #2197889
11/17/16 12:04 PM
11/17/16 12:04 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Trying to order head studs for the Trick Flow heads..
Summit has a stud kit (TFS-61604304) with 22 short studs and 10 long studs (don't mention length) - this kit apparently is only available with hex nuts.
What do I need to order if I want the best fitting studs?
AndyF suggested 24 x 2.725 studs and 10 x 5.000 studs - is this still the way to go?
This doesn't include the rocker arm studs, correct? AndyF suggested 10 x 2.750 for the rocker arm shafts.
Also looking for 12 point nuts.
What are the right ARP part numbers for the above studs and nuts, washers?
Re: Trick Flow heads [Re: fast68plymouth] #2198101
11/17/16 06:28 PM
11/17/16 06:28 PM
AndyF Offline
AndyF  Offline
I use the 2.725 long studs since they are shorter and will clear the header flange. I told Trick Flow that but they went with the longer studs in their kit. I also told ARP about it but they sell the longer studs in their kits. So whatever......
You can just order the studs by description from ARP. I think they have a website now with a shopping cart but you'll have to check. I also order ARP stuff from Summit sometimes but Summit doesn't have everything in their catalog.
Re: Trick Flow heads [Re: fast68plymouth] #2198108
11/17/16 06:39 PM
11/17/16 06:39 PM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Thank you Andy! Why 24 short studs and not 22 like in the TF kits?
What's the thread for the studs? 3/8-16 and 3/8-24?
Can't find the 2.725 studs online. Do you have a part number?
Re: Trick Flow heads [Re: fast68plymouth] #2203327
11/27/16 02:54 PM
11/27/16 02:54 PM
AndyF Offline
AndyF  Offline
Here is the next article from the Hot Rod website:
http://www.hotrod.com/articles/test-intake-manifolds-carburetors-440-stroker-search-ultimate-power/
I think I'm at the end of the road in terms of making power with the 240 heads. We're up into sonic choke range so the engine just doesn't pick up power very easy anymore.
Re: Trick Flow heads [Re: fast68plymouth] #2203341
11/27/16 03:13 PM
11/27/16 03:13 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
Are you going to back-to-back the 240's and 270's on the other short block?
Re: Trick Flow heads [Re: fast68plymouth] #2203411
11/27/16 05:57 PM
11/27/16 05:57 PM
AndyF Offline
AndyF  Offline
I'm not sure about a back-to-back test since that is so much work but I do plan to run the 270 heads on the same 470 inch shortblock with the same camshaft.
Re: Trick Flow heads [Re: AndyF] #2203436
11/27/16 06:47 PM
11/27/16 06:47 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I noticed that a few days ago, it's really impressive 700+ hp with a smallish, modest CR motor beer. How hard would it be to get the M1 tunnel ram digitally scanned and 3d printed? work
Re: Trick Flow heads [Re: AndyF] #2203455
11/27/16 07:26 PM
11/27/16 07:26 PM
So. Burlington, Vt.
So. Burlington, Vt.
That's close enough for me.
Re: Trick Flow heads [Re: Skeptic] #2203484
11/27/16 08:30 PM
11/27/16 08:30 PM
AndyF Offline
AndyF  Offline
Just a matter of someone being willing to spend the money to get it digitized and reproduced. I might do it someday, I'm getting closer and closer to that kind of stuff.
Re: Trick Flow heads [Re: AndyF] #2203491
11/27/16 08:45 PM
11/27/16 08:45 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I brought that up because there are a couple of companies nearby that do the digitizing and printing. I'd love to have the grilles for my Barracuda in a lightweight material, not heavy pot metal. The intake would be nice, just for availability and losing a few Lbs wouldn't hurt either. I haven't talked to anyone about the actual cost of getting it done.
Re: Trick Flow heads [Re: fast68plymouth] #2203562
11/27/16 10:31 PM
11/27/16 10:31 PM
AndyF Offline
AndyF  Offline
They didn't print the dyno results for some reason but I think I can post them on here since it is a pdf file.
Attached PDF document
Graph.pdf (288 downloads)
