Page 4 of 4 1 2 3 4
Re: Launch critique [Re: mikeysmopars] #2168794
10/06/16 02:03 AM
10/06/16 02:03 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
well I'm a small block guy so I'm a bit slow.... My 60 changed quite a bit going from 5800 to 6200. Definitely didn't get up on the tire like the lower stall one did. I didn't experience loss of traction with the stall increase, but loss of performance was definitely noted.... unless you are talking strictly bracket stuff because the 1.34 60 times pretty much every hit made the car very predictable. Our last visit to Famoso I ran my best ET to date Sunday am and that definitely wasn't "good" air. That's with the "other" converter I bought that is tighter. Dave also noted it was definitely up on the tire over our March Meet passes. Think data from that weekend we're around 1300 DA. Can't say this is your issue.... but I sure wish you'd kept the old converter and could throw it in for a weekend.
Re: Launch critique [Re: mikeysmopars] #2181247
10/24/16 07:49 AM
10/24/16 07:49 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I'll bump this again to see if any updates?
Re: Launch critique [Re: racerx] #2181349
10/24/16 12:38 PM
10/24/16 12:38 PM
fresno ca
mikeysmopars Offline OP
fresno ca
Plan to run on the fifth of November(Super Chevy race) grin
I'll update !
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Launch critique [Re: mikeysmopars] #2181402
10/24/16 01:49 PM
10/24/16 01:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'll update !
I`ll see where things are in my world and maybe roll out to race w/you guys...........
Re: Launch critique [Re: Thumperdart] #2181520
10/24/16 04:00 PM
10/24/16 04:00 PM
fresno ca
fresno ca
I'll update !
Cool thumbs
Re: Launch critique [Re: mikeysmopars] #2190708
11/06/16 02:07 PM
11/06/16 02:07 PM
fresno ca
fresno ca
Ok had a rough week but changed my front springs,loaded up and went to Famoso.
Left the front shocks as they were. Full loose on extension, rear shocks were set at 3 which is in the middle. Slicks set at 12lbs. Got only one run eyesand was the best yet but again it spun. The hit was with the brake and 3400 chip. That was the tenth run on all the new changes and creeping forward but the car will not rotate. It's comes up and as soon as it starts to pull the front, it starts spinning. I couldn't stick around because I was supposed to be at my wife's birthday so I attempted a second run but the car died on the line and didn't refire.r really feel like scrapping the high dollar front end and going back to stock rolleyes
Re: Launch critique [Re: mikeysmopars] #2190711
11/06/16 02:17 PM
11/06/16 02:17 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Good Job, what is Your finish line rpm?
Re: Launch critique [Re: mikeysmopars] #2190734
11/06/16 02:56 PM
11/06/16 02:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Left the front shocks as they were. Full loose on extension. The car will not rotate. It's comes up and as soon as it starts to pull the front, it starts spinning.
You have answered your own problem right it this part of the text. Tighten the front rebound.
Doug
Re: Launch critique [Re: Sport440] #2190755
11/06/16 03:34 PM
11/06/16 03:34 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By Sport440
IMO, on the hit your not getting Near enough Rear separation. Your front suspension is to loose and popping to high up then rebounding back down causing you to spin.
So, IMO you don't need a looser front setting. From the vid it pops up right now and bounces several times while unloading the back. I think you need to promote rear separation.
The front needs to come up more gradually and smoothly.
Yep I agree, Stated that at the beginning of this thread, fell on deaf ears I guess, but sometimes it is hard to remember every ones post. Try it Tighter next time out and work on the rear separation as stated. up
Re: Launch critique [Re: Dduster] #2190786
11/06/16 04:35 PM
11/06/16 04:35 PM
fresno ca
fresno ca
[quote=Dduster]Good Job, what is Your finish line rpm? [/quot
Crossed @ 7800
Re: Launch critique [Re: mikeysmopars] #2191029
11/06/16 11:06 PM
11/06/16 11:06 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Full loose is NOT gonna work
Re: Launch critique [Re: mikeysmopars] #2191093
11/07/16 12:11 AM
11/07/16 12:11 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Thank You up
Re: Launch critique [Re: mikeysmopars] #2191228
11/07/16 06:16 AM
11/07/16 06:16 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Hang in there champ,don't throw in the flag yet. I've been following this thread for a while now. Cause I'm having similar problems(transferring weight)talk to Bob about a month ago and he recommend sending in the shocks for revalveing. Hope this works for me luck one thing I will say bout this setup is it makes pulling the pan/headers easy yellow and it goes straight. I had a best of 1.29 this year with this setup and that's with the shocks set full loose it still seems to tight for me. My plans over the winter is to pull the shocks and send them out.
Re: Launch critique [Re: mikeysmopars] #2191421
11/07/16 02:00 PM
11/07/16 02:00 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
When you get ready to scrap that high dollar front end, I will be glad to take that junk, because that definitely is NOT the problem.
People get SO caught up in the posts on THIS site, about "it's got to have 5" or more of travel, or it won't work" that they can't see the forest for the trees.
Another thing, if it has the fronts off the ground.....it IS transferring and it IS rotating. Not sure what else you think it's supposed to do
Re: Launch critique [Re: mikeysmopars] #2191455
11/07/16 02:28 PM
11/07/16 02:28 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Video dizuster posted acouple months ago it may beable to shed some light on your issues
https://youtu.be/sjZDXBXRC9Q
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Launch critique [Re: turbo toad] #2191546
11/07/16 03:55 PM
11/07/16 03:55 PM
fresno ca
fresno ca
Monte you have a PM
Re: Launch critique [Re: mikeysmopars] #2191600
11/07/16 05:00 PM
11/07/16 05:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I would agree to tighten up the front. The rear may need a better shock or increased rear valving. Video is always best
Page 4 of 4 1 2 3 4
