Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2194016
11/10/16 03:12 PM
11/10/16 03:12 PM
USA
3
360view Offline OP
Moparts resident spammer
360view  Offline OP
3
USA
I hope you can reclaim it.
Here is a do it yourself desulfator project if a conventional charger is not enough.
http://www.alton-moore.net/graphics/desulfator.pdf
The author says it can take a month to break up the large sulfate crystals
Sample quote
Usage
It should be emphasized that pulsing energy to and from the battery happens at less than 100 percent efficiency. This circuit draws about 40 mA from the battery while in operation (less than 1 amp-hour per day), so some additional charging source is needed. For reconditioning a sulfated battery, I simply clip the circuit across the battery terminals in parallel with a 30 watt solar panel.
In my initial testing, it took a month to partially reclaim a pair of golf cart batteries that had been allowed to sit, discharged, for almost a year. They had such a high internal resistance that a very small current would take the terminal voltage over 16 volts.
For use in a functioning power system, you can clip the circuit across the main battery terminals, using as short a lead length as possible. When external equipment, such as an inverter, is connected across a battery bank, then additional low impedance paths are formed. The desulfator’s current pulses will happily flow down these paths as well, and it serves no purpose for the pulses to flow into the inverter.
End quote
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2194920
11/11/16 08:32 PM
11/11/16 08:32 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Originally Posted By 360view
Any experiences with the Blue Top Optimas?
The cranking blue top is the same as a red top, the deep cycle blue top is the same as a yellow top. The only differences being the marine terminal style and warranty.
68 Barracuda Formula S 340
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2196276
11/14/16 04:39 PM
11/14/16 04:39 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It turns out that my Optima is, indeed, dead.
My charger says there is an internal short and I'm fairly sure that's what was causing my electrical issue.
The date on the side of the battery is December 2006. I can't complain. That thing doesn't owe me anything after 10 years.
- Stu Harmon
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2196482
11/14/16 11:01 PM
11/14/16 11:01 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
I had one last 11 years. Same thing, can't complain.
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2196725
11/15/16 01:12 PM
11/15/16 01:12 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My smart charger has a desulfate program built into it. The unit draws the battery down, pulses a charge backwards through the battery to clear the plates, then bring it back up to full charge. The process takes at least 24 hours to complete.
- Stu Harmon
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 360view] #2196867
11/15/16 05:22 PM
11/15/16 05:22 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
My Yellow top lasted 3 years. I killed it by letting it discharge too far. I tried the parallel charging trick and it would come up to voltage, but it would die soon afterward. Standard lead/acid batteries seem to tolerate neglect better.
Re: Your experiences with Optima/Odyssey/AGM lifespans? [Re: 74RALLYE] #2196901
11/15/16 06:29 PM
11/15/16 06:29 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My truck will sometimes sit for a few weeks without being started. The Optima lasted 10 years with that kind of use.
I had a brake light switch that would hang closed and kill the battery. I don't know if that did it in or not.
I replaced the switch last week but the damage may have already been done.
- Stu Harmon
