Re: Firing issues
[Re: Texas383]
#2193855
11/10/16 12:20 PM
11/10/16 12:20 PM
Posts: 678 Marshall TX
Texas383
Marshall TX
Bought a compression gauge and took a reading or two yesterday evening.
I took the readings with engine cold and just turning it over and not with engine running. With a deeply saddened heart I discovered that #3 only had 30psi. I tested #7 and it had 110psi. I have to assume #6 has low compression as well.
Now....moving forward. Did this eat up just rings or the cylinder wall too? The block is bored 060 and I need to know if I can just re-ring or what...?
1969 Y2 Super Bee 1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: Firing issues
[Re: Texas383]
#2193859
11/10/16 12:27 PM
11/10/16 12:27 PM
Challenger 1
Cincinnati, Ohio
Now....moving forward. Did this eat up just rings or the cylinder wall too? The block is bored 060 and I need to know if I can just re-ring or what...? Won't know until you take it apart. Why is it bored .060 over already? Was it bored twice to get to .060 over? I thought it was a original motor...I guess not. I have done plenty off re hones and re rings without a bore job with good success. Sorry to hear, more than likely both are worn. Squirt some oil in the spark plug hole and retest. If the numbers go up then it's saying the rings are worn. If not then the valve seal is bad.
Re: Firing issues
[Re: Texas383]
#2193908
11/10/16 01:20 PM
11/10/16 01:20 PM
Texas383
Marshall TX
It's not the original motor... but it is a 1969 HP motor that was in a '69 Road Runner. I rebuilt and put the motor in back in '89. It needed a 030 over bore then. Back in 2000 I rebuilt again and it needed 060.
Re: Firing issues
[Re: Texas383]
#2194148
11/10/16 06:53 PM
11/10/16 06:53 PM
Texas383
Marshall TX
I would guess in the 30K range(speedo was broken for a few years and gear change when speedo worked)
Re: Firing issues
[Re: Texas383]
#2194175
11/10/16 07:41 PM
11/10/16 07:41 PM
Challenger 1
Cincinnati, Ohio
Gotcha, sucks 30 is low miles.
I am betting with that low of miles you can rehone and re ring and it will be fine.
Re: Firing issues
[Re: Texas383]
#2194179
11/10/16 07:48 PM
11/10/16 07:48 PM
Posts: 5,169 CT
GTX MATT
CT
30 psi is way low I think you have a burned valve on that cylinder...
Re: Firing issues
[Re: Texas383]
#2194205
11/10/16 08:24 PM
11/10/16 08:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Or a set of Edelbrock heads
Re: Firing issues
[Re: Texas383]
#2194631
11/11/16 11:46 AM
11/11/16 11:46 AM
Texas383
Marshall TX
It's not smoking any or getting oil on the plug.... so would that eliminate the rings being gone?
Sadly it will have to be after the Holidays and the New Year before I can do anything about it. Plus an impending move in 2017.
One thing after another it seems sometimes....
