Re: Heavy rear for mid 80's ram charger? [Re: savoy64] #2200312
11/22/16 12:40 AM
11/22/16 12:40 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Originally Posted By savoy64
here is hoping your rear is a 5 on 5.5----and either you go to a stock dodge truck 9.25 or pony up money to have someone build you a custom dana 60.....
If you can find a Jeep Gladiator with a Dana 60-2 in back you are nearly there. The casting in the case web says 60-2. I have one of those units and had the drivers side axle tube and axle narrowed by 6". The axle shafts take Set7 Timken tapered roller bearings and are 35 spline, stock with a 5 on 5.5" bolt circle. I was going to put it under my '87 D100, but I bought a '98 Ram 2500 and sold the D100. Now I will probably put it under the '72 Cuda and narrow it again with different axles & brakes.
The attached photo is of the Jeep that uses a Dana 60-2 rear with 12" brakes and 5 on 5.5" bolt circle. If you use 16" wheels they will clear the brake drums.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Heavy rear for mid 80's ram charger? [Re: Polarapete] #2201328
11/23/16 05:55 PM
11/23/16 05:55 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
It's fine. Remember than many factory cars and trucks came with the 9.25 behind big blocks between 1974 and 78
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2205147
11/30/16 11:44 AM
11/30/16 11:44 AM
scratchnfotraction Offline
dodge had a 8 3/4 that was a 5 on 5.5 for the 4x4 trucks\
a c-body 8 3/4 is same width as a d-series truck RC/TD 9 1/4- 8 1/4
can be had small or large wbp
I used a 8 3/4 A-body 8 3/4 to tub my 88-440 truck. a-body truck share the same 43" perch centers so it a bolt in on top of the leaf with car u-bolts/shock plates
if you don't want narrow a c-body 8 3/4 only needs perches moved to 43" centers and on top of tubes for axle under leafs.
B-body D60 is what I would look for. then it only needs a perch spacing change
or take a 8 lug D60 and have it narrowed to 59" have car bearing cups welded on and buy Moser C-body axles good to 500HP.
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2205174
11/30/16 12:41 PM
11/30/16 12:41 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I put an 8 3/4 rear in my 86 RC 2wd with the last few years that had the 5 on 5 1/2 pattern axles(72 through 74 4wds?).
I'm now running a Dana 60 8 lug rear with 8 lug(heavy 3/4 ton front end) up front....all from an 85 2wd 1 ton. NOT that the 8 3/4 failed. I just like lots of woe...with the bigger breaks....lol.
I'm not a fan of the 9 1/4.....it seems that I've seen more of them being replaced than 8 1/4s......but what causes them to fail......who knows.
As in was it operator error......like taking them under water or letting them leak until there is no oil left, again my two cents.....which around here doesn't mean much. LOL
Moparlee
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2205195
11/30/16 01:25 PM
11/30/16 01:25 PM
most issues I have seen or had have been the pinion nut coming loose/pinion bearing wipe out/crush sleeve adjustment or lack of.
every one I invested in got a new set of bearing and set up with shims and solid spacer. never issues after that with them.
I prefer the 8 3/4 for gear change and I can run non adjustable green bearings and Moser axle any size needed.
30 min R&R and either a 2.76 3.23 3.91 gear ratio under my bench.
Re: Heavy rear for mid 80's ram charger? [Re: scratchnfotraction] #2206630
12/02/16 08:35 PM
12/02/16 08:35 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I have revised my post about the Dana 60-2 and included a reference photo. See it a couple of posts above.
I also have a 9.25" truck rear in my stash and when I have a chance I will drop it off at the recyclers. Years ago, at the yard I worked at, we took in a Dodge truck that had a 9.25". The pinion nut loosened and when the axle seized up the truck was wrecked cry
2008 Honda Element
