Re: Help removing torsion bar [Re: RaiderLefty] #218673
02/09/09 02:49 PM
02/09/09 02:49 PM
Hunt Valley, Maryland
1fastrunner Offline OP
Now I see what you're talking about. What size would I need?
Re: Help removing torsion bar [Re: 1fastrunner] #218674
02/09/09 04:49 PM
02/09/09 04:49 PM
It's free in the back, but hung up in the LCA. I can push the LCA away from the k frame, and it moves freely out the back, but it comes back when released. How can I free it up from the LCA?
Re: Help removing torsion bar [Re: 1fastrunner] #218675
02/09/09 04:53 PM
02/09/09 04:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you remove the upper a arm bump stop to allow the suspension to drop all the way down? I take it you removed the adjuster bolts.
Re: Help removing torsion bar [Re: 1fastrunner] #218676
02/09/09 04:54 PM
02/09/09 04:54 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
It's stuck with old cruddy grease and/or rust in the control arm socket , push the part back out of the way and drop out the engine trans then pull the parts out of the car so you can work on them OR buy or make a removal tool that clamps to the bar and won't knick up the surface , bolt the LCA back in place and beat it out of the control arm .
Re: Help removing torsion bar [Re: stumpy] #218677
02/09/09 05:00 PM
02/09/09 05:00 PM
The bump stop was never there, and the tension bolt has been loosened.
Re: Help removing torsion bar [Re: 1fastrunner] #218678
02/09/09 05:35 PM
02/09/09 05:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Removing it will allow a little more movement which may be all you need.
Re: Help removing torsion bar [Re: stumpy] #218679
02/09/09 06:00 PM
02/09/09 06:00 PM
Westchester, NY
JM67RT Offline
JM67RT  Offline
Westchester, NY
I just went through the same issue. I whacked on the tool for a week and couldn't get it to budge. Tried everything and still no luck. My buddy came over Saturday and gave it a shot with my sledge, still no good. He then got his handheld sledge that was about the same weight as mine but with a longer handle. After a few whacks it came loose. Use the biggest BFH you can find!
Re: Help removing torsion bar [Re: JM67RT] #218680
02/09/09 08:17 PM
02/09/09 08:17 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
Jim,
Try this before you go completely crazy:
Using a floor jack, lift up on the lower control arm at the wheel hub. Just a little bit. Once you find the "perfect" spot that releases all tension on the torsion bar, you may be able to literally pull it straight out with just your hands!
You may have to go up/down in little increments to get the lower control arm in the perfect spot to get the torsion bar to slide out.
Stan
Re: Help removing torsion bar [Re: HemiStan] #218681
02/09/09 08:38 PM
02/09/09 08:38 PM
I already tried that a little, but I'll try again tomorrow. I've soaked everything for the night, my upper ball joints are also contributing to my "Torsion" headache. I think the drivers side is good to go, it's the passenger side that's giving me fits. It goes through the back alright, but is getting hung up somewhere through the LCA. I am ready to go crazy! I needed some sense of accomplishment today, so I did some other things. I disconnected my speedo cable, backup switch, and my clutch linkage. Tomorrow's another day.
Re: Help removing torsion bar [Re: 1fastrunner] #218682
02/10/09 12:20 AM
02/10/09 12:20 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
If you haven't already tried this, hit the socket on the lca that the torsion bar slips in with a large hammer several times. This has worked for me.
Re: Help removing torsion bar [Re: pushbutton] #218683
02/10/09 09:36 AM
02/10/09 09:36 AM
NJ
440challenger Offline
NJ
Mine were rusted in, i had to cut them out. They dont cut to easily!!
Re: Help removing torsion bar [Re: 440challenger] #218684
02/10/09 09:24 PM
02/10/09 09:24 PM
Finally some good news, I got one out and the other very close. I can rock it back and forth with a vise grip and a towel around it by hand. It's getting hung up on the back where it's supposed to come out. I can feel a slight metal ridge in a couple spots. I need to find a way to gring out some of the metal around the opening. This celebration will be brief, my other ongoing mission is the upper ball joints. I'm trying to borrow a impact driver, and hopefully my wimpy compressor will be up to the job. Thanks, for all your tips and suggestions, I'm not sure which one did it, and maybe even a combination. Now I need to find a way to get this PB Blaster oder off me.
Re: Help removing torsion bar [Re: 1fastrunner] #218685
02/10/09 10:52 PM
02/10/09 10:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There should be no resaon to grind anything. Are you sure you're not feeliung the clip?
Re: Help removing torsion bar [Re: 1fastrunner] #218686
02/10/09 10:55 PM
02/10/09 10:55 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Spill some used gear oil on yourself... you will never smell the PB again..
Re: Help removing torsion bar [Re: stumpy] #218687
02/10/09 10:56 PM
02/10/09 10:56 PM
No clip, it seems at one time it had been removed and possibly hammered in. I'm guessing the hammer may have missed the mark and pushed some metal in the way. i can feel a slight lip in two places with my finger.
Re: Help removing torsion bar [Re: 1fastrunner] #218688
02/10/09 10:58 PM
02/10/09 10:58 PM
You made it sound like it was stuck in the LCA ?????
Pull the nut off the pivot shaft on the LCA , stick a prybar between the LCA and the K frame and pry it back , if the clip is out itshould come out. The ridge you are feeling is the ridge that keeps the clip in place DO NOT GRIND it out .
Re: Help removing torsion bar [Re: JohnRR] #218689
02/10/09 11:01 PM
02/10/09 11:01 PM
I'll have a look tomorrow after work.
Thanks,
