Re: Help removing torsion bar
[Re: 1fastrunner]
#218676
02/09/09 04:54 PM
02/09/09 04:54 PM
Posts: 75,103 A Banana Republic near you.
JohnRR
It's free in the back, but hung up in the LCA. I can push the LCA away from the k frame, and it moves freely out the back, but it comes back when released. How can I free it up from the LCA? Jim
It's stuck with old cruddy grease and/or rust in the control arm socket , push the part back out of the way and drop out the engine trans then pull the parts out of the car so you can work on them OR buy or make a removal tool that clamps to the bar and won't knick up the surface , bolt the LCA back in place and beat it out of the control arm .
[Re: HemiStan]
#218681
02/09/09 08:38 PM
02/09/09 08:38 PM
Posts: 2,126 Hunt Valley, Maryland
1fastrunner
I already tried that a little, but I'll try again tomorrow. I've soaked everything for the night, my upper ball joints are also contributing to my "Torsion" headache. I think the drivers side is good to go, it's the passenger side that's giving me fits. It goes through the back alright, but is getting hung up somewhere through the LCA. I am ready to go crazy! I needed some sense of accomplishment today, so I did some other things. I disconnected my speedo cable, backup switch, and my clutch linkage. Tomorrow's another day. Jim
[Re: 440challenger]
#218684
02/10/09 09:24 PM
02/10/09 09:24 PM
1fastrunner
Finally some good news, I got one out and the other very close. I can rock it back and forth with a vise grip and a towel around it by hand. It's getting hung up on the back where it's supposed to come out. I can feel a slight metal ridge in a couple spots. I need to find a way to gring out some of the metal around the opening. This celebration will be brief, my other ongoing mission is the upper ball joints. I'm trying to borrow a impact driver, and hopefully my wimpy compressor will be up to the job. Thanks, for all your tips and suggestions, I'm not sure which one did it, and maybe even a combination. Now I need to find a way to get this PB Blaster oder off me. Jim ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 1fastrunner]
#218686
02/10/09 10:55 PM
02/10/09 10:55 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Spill some used gear oil on yourself... you will never smell the PB again.. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: 1fastrunner]
#218688
02/10/09 10:58 PM
02/10/09 10:58 PM
JohnRR
You made it sound like it was stuck in the LCA ?????
Pull the nut off the pivot shaft on the LCA , stick a prybar between the LCA and the K frame and pry it back , if the clip is out itshould come out. The ridge you are feeling is the ridge that keeps the clip in place DO NOT GRIND it out .
