Re: is my 4 speed junk?
[Re: JohnRR]
#2196484
11/14/16 11:02 PM
11/14/16 11:02 PM
Posts: 959 Cincinnati,Ohio
jcastle1
Cincinnati,Ohio
i pulled the trans over the weekend and pulled the side cover off tonight. nothing seems out of place. How do I know what to look for? I rebuilt this several years ago and looks the same as before.I'm a little lost at this point
[Re: jcastle1]
#2196491
11/14/16 11:14 PM
11/14/16 11:14 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Check cluster for end play. Move it back and forth. Use your judgement for clearance, as I don't know if there is an actual spec. Excessive motion would indicate a thrust washer worn out. After that, I would pull the tail assembly off and check both main bearings, input rollers and spin cluster gear and listen for a similar noise to what you heard.
[image][/image]
[Re: cudaman1969]
#2201032
11/23/16 03:32 AM
11/23/16 03:32 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
So Dan @ Brewers said the cluster washers were worn. Did you check out the YOU TUBE video on the 833 making noise? If the washers are worn the cluster gear will move back and forth hitting the sides of the gears on the main shaft as I posted earlier.
[Re: jcastle1]
#2201274
11/23/16 04:17 PM
11/23/16 04:17 PM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
I suspect that you are going to find something fouled up in the clutch. Something that causes intermittent disengagement issues. Maybe a broken spring, cracked disc hub, lining delamination, etc. Check it over good.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: rowin4]
#2201290
11/23/16 04:49 PM
11/23/16 04:49 PM
Posts: 766 Ohio
Dan Brewer
Ohio
So Dan @ Brewers said the cluster washers were worn. Did you check out the YOU TUBE video on the 833 making noise? If the washers are worn the cluster gear will move back and forth hitting the sides of the gears on the main shaft as I posted earlier. They are not too thin, just full of trash which scratched up the cluster real bad. Trans was dis-assembled when I looked at it but I doubt it has more than .025" endplay even with the washers bad. I suspect at this point something in the bell also, the noise is not always there. It can come or go, even in the same gear.
