Piston Failure: What would cause this? #2182458
10/25/16 07:00 PM
10/25/16 07:00 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
This is a cast piston removed from a buddies quad. The majority of the damage is on the intake side. What do you guys think would cause this type of failure? work
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182470
10/25/16 07:23 PM
10/25/16 07:23 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Pilled it and killed it???
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182473
10/25/16 07:28 PM
10/25/16 07:28 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
My guess would be lean .
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182488
10/25/16 07:41 PM
10/25/16 07:41 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
That's a timing burn. Now what CAUSED it to be grossly over timed is another matter
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182606
10/25/16 10:15 PM
10/25/16 10:15 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
2 stroke mix or injection? 4 stroke?
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182625
10/25/16 10:22 PM
10/25/16 10:22 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Ouch Trent down
[img] [/img]
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182643
10/25/16 10:43 PM
10/25/16 10:43 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
does all 8 pistons show some of the same thing or just one ?
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182648
10/25/16 10:45 PM
10/25/16 10:45 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
QUAD people.... smile
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182650
10/25/16 10:46 PM
10/25/16 10:46 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'll go with oil consumption to the point it started to become a fuel..... black death. smile
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182709
10/25/16 11:45 PM
10/25/16 11:45 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Is that the remains of an oil ring? Looks like a 2 stroke piston to me otherwise.
I've seen 2 stroke pistons from a 440 Rotax that looked like that except they were beat right to the wrist pin. Diagnosis was easy. Bad nitrous/methanol tune.
A few details wouldn't hurt...
Kevin
Re: Piston Failure: What would cause this? [Re: Twostick] #2182764
10/26/16 01:31 AM
10/26/16 01:31 AM
Tucson AZ,
Tucson AZ,
This piston is from a single cylinder, air cooled, 4 stroke quad. That is the oil ring but is filled with aluminum at this point. The cylinder wall has aluminum stuck to it and the exhaust valves were hung open due to aluminum build up on the exhaust stems.
This is a buddies quad which he has had for several years with the exception of loaning it to a friend prior to this last trip to the dunes where it suffered this failure.
Given the substantially lower elevation of the dunes, my first thought was a lean condition but supposedly the jetting had been corrected.
I'm thinking this looks more like detonation but the fact that it is offset to the intake valves makes me think there's more to the story.
On quads, I'm not sure ignition timing is all that adjustable. At least not commonly adjusted that's for sure.
A lean condition makes the most since, detonation due to incorrect timing looks more evident and lastly, getting sprayed at some point doesn't seem to far fetched in my opinion.
Just doesn't look like a normal failure to me and I think he either needs the rest of the story from his friend or he better start looking real good for the cause.
What are your guys thoughts? Doesn't this one seem weird?
Re: Piston Failure: What would cause this? [Re: J_BODY] #2182770
10/26/16 01:44 AM
10/26/16 01:44 AM
Tucson AZ,
Tucson AZ,
If it was a 2 stroke, I wouldn't even have to ask why it blew up. It's what they do. grin
I actually have a CR500 I'm getting ready to put back in a quad. I think it's been long enough that I'm ready to give the two stroke another shot. I'm sure it'll be in pieces again soon enough though. no
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182813
10/26/16 06:50 AM
10/26/16 06:50 AM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
air cooled 4 stroke...most likely got hot, or lean.
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182814
10/26/16 06:51 AM
10/26/16 06:51 AM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
we run 2 strokes as well, a 250r and a banshee....usually get a few hard seasons out of them. then a fresh hone and $200 wiseco piston kit......can't beat a 2 stroke! brappp!!
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182910
10/26/16 11:15 AM
10/26/16 11:15 AM
crlush Offline
crlush  Offline
It's a cheap cast piston that was run hard lean, probably has a gummed up carb. I run alot of dirtbikes/4 wheelers/snowmobiles and with today's gas I'm always cleaning carbs from them sitting on off seasons. I did the exact same thing on an old 2 stroke snowmobile that someone gave me, except it blew a hole right through. It sat for 5 yrs and when I started it up it ran pretty good and against my better judgement I decided to take it for a ride just down the street wasn't even a quarter mile and it started running like crap, barely made it home before it quit.had aluminum everywhere.
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182924
10/26/16 11:44 AM
10/26/16 11:44 AM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Non-ethanol gas is your friend with small carbed motors. Water and ethanol will separate out and that stuff will leach the copper from the jets, changing them. I bet the carb has a bunch of green stuff on the inside of the float bowl if that is the root cause.
Re: Piston Failure: What would cause this? [Re: Airwoofer] #2182942
10/26/16 11:59 AM
10/26/16 11:59 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I was going to ask what fuel is used , if it's E10 then it's probably from being lean.
Mainstream Media is the new Pravda
Re: Piston Failure: What would cause this? [Re: MadMopars] #2182947
10/26/16 12:02 PM
10/26/16 12:02 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
1 cylinder or 2?
Air cooled or liquid?
Fuel used?
2-stroke oil used?
Mixing ratio?
Ignition setting / timing?
Operating conditions?
How long on that piston & rings?
Iron (boreable) or Nikasil bore?
Didn't burn a hole through the piston crown, but the heat sure toasted the ring land... and the skirt is just plain ugly. Is that the exhaust side of the piston shown in the pic? Did it hang a ring in the port?
Re: Piston Failure: What would cause this? [Re: BradH] #2182948
10/26/16 12:05 PM
10/26/16 12:05 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Originally Posted By BradH
1 cylinder or 2?
Fuel used?
2-stroke oil used?
Mixing ratio?
Re: Piston Failure: What would cause this? [Re: JohnRR] #2183054
10/26/16 03:00 PM
10/26/16 03:00 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
How about sucking in allot of sand thru the air filter if it has one?
