Re: Piston Failure: What would cause this? [Re: MadMopars] #2183265
10/26/16 08:31 PM
10/26/16 08:31 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Re: Piston Failure: What would cause this? [Re: TRENDZ] #2183877
10/27/16 03:44 PM
10/27/16 03:44 PM
dogdays Offline
dogdays  Offline
Top of piston marking = detonation, which also broke off the part of the piston which then bounced around making more dents.
The black marks on the side of the piston occurred during the failure and have been called "black death".
R.
Re: Piston Failure: What would cause this? [Re: JohnRR] #2184081
10/27/16 08:03 PM
10/27/16 08:03 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By JohnRR
Originally Posted By BradH
1 cylinder or 2?
Air cooled or liquid?
Fuel used?
2-stroke oil used?
Mixing ratio?
Ignition setting / timing?
Operating conditions?
How long on that piston & rings?
Iron (boreable) or Nikasil bore?
Didn't burn a hole through the piston crown, but the heat sure toasted the ring land... and the skirt is just plain ugly.
This piston is from a single cylinder, air cooled, 4 stroke quad.
Sh!t, like I got time to read the whole post? wink
Hmmm... yup, run hard and put away broke. eek
Glad it's not mine.
