Aluminum Big Blocks
#2180413
10/22/16 05:37 PM
10/22/16 05:37 PM
Posts: 705 USA
rftroy
USA
I'm considering an aluminum RB block for my Challenger. From my searching so far, it seems that the options are: - Keith Black - Bill Mitchell - Indy
It looks as though Dart does not make an aluminum Chrysler block.
From multiple postings here, and elsewhere, KB makes a very nice part, but the odds of actually getting one are long, and indications are that he may not make it in business much longer.
Keeping in mind that it is internet complaining, there still seem to be a lot of negative reports on Bill Mitchell, both from Mopar and Chevy people.
I've dealt with Indy before, and understand some of the service issues, but I'm assuming they make a good block. They have that reputation. Is the Indy block a race only piece? This will be going in a Pro-Touring car. I have read that the block only comes in a Hemi mount configuration.
Are these the only options, and are any of them any good?
Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Aluminum Big Blocks
[Re: fullmetaljacket]
#2180483
10/22/16 08:30 PM
10/22/16 08:30 PM
Posts: 705 USA
rftroy
USA
Thanks, guys. Sounds good.
I'll give a call to Best on Monday.
It appears from the Indy website that the block comes with Hemi style mount interfaces. Schumacher has mounts, and I'm guessing it's one of his more popular kits, so that's not a problem.
Block appears to be machined for stock water pump, fuel pump and timing chain cover. Any other issues or things I need to plan for to install in a stock configuration?
Is it Best Machine Racing Engines in Farmington Hill, MI?
Bob
[Re: AndyF]
#2180628
10/23/16 12:45 AM
10/23/16 12:45 AM
Posts: 705 USA
rftroy
USA
Might be a better idea to get a Hemi K frame rather than use the conversion mounts. So are you implying that there is a problem with the Schumaker mounts? Are they weak? Do they change the load path into the block and cause different stresses than stock? Do they generate interference issues because of non-stock geometry? Bob
[Re: Cab_Burge]
#2180649
10/23/16 01:19 AM
10/23/16 01:19 AM
Posts: 705 USA
rftroy
USA
Well, this will not be a race car. It is for street driving, mostly mountain and windy roads. A plate will rigidly attach engine to frame and transmit unacceptable vibration, no?
So, back to the Schumacher mounts, what is the issue with using them?
Bob
[Re: rftroy]
#2180719
10/23/16 08:30 AM
10/23/16 08:30 AM
Posts: 2,937 A shed in England
Tig
A shed in England
I've used a motor plate for many years, never really noticed the vibration. Drives smooth, when friends drive my car they often comment on how "tight" everything feels and how nice it is to drive. Seems they were expecting some shonky, rattley race car ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: rftroy]
#2181214
10/24/16 01:38 AM
10/24/16 01:38 AM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
I'm going through the same thing now except KB has my money for a hemi block and I don't have a block after two years.
I also need a wedge block. I talked to best machine and they get semi finished blocks from Indy and cut the bores, clearance and deck to your specs. No first hand experience but by reputation they do a good job and they were pleasant and helpful when I spoke to them on the phone.
BG has Indy do all the machining to your specs. I talked to them about ordering a block and getting it at the Indy show (cheapest route) but I am a little uncomfortable buying a block from one vendor and having it machined by another vendor. BG will machine a block at their local shop but it costs more.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: rftroy]
#2181600
10/24/16 06:07 PM
10/24/16 06:07 PM
Posts: 19,395 Las Vegas
Al_Alguire
Las Vegas
I have a KB block engine a World(bill Mitchell)and an Indy block engine here. All three worked well and all three had some machining issue that had to be fixed. I have run World and KB stuff in the past with no block issues from either as well. This is our first Indy deal so time will tell but don't expect any issues from it.
[Re: 440Jim]
#2181920
10/25/16 01:37 AM
10/25/16 01:37 AM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
I have heard the Indy block may have interference issues with some headers as the oil pan rail (mounting surface) is a little wider.
I had this problem with TTI headers and a Indy block. I had a 3/8" header flange welded onto the TTI header flange to space the header away from the motor. It still needed some dinging on the tubes to clear.
1974 Roadrunner
1967 Charger
