Misaligned Side Glass? - 1967 B Body
#2181615
10/24/16 06:25 PM
10/24/16 06:25 PM
Posts: 1,379 Airdrie, AB
Mills
Airdrie, AB
Just finished replacing all the weatherstripping on my '67 Satellite and I noticed the front to rear side glass (glass channel weatherstripping) gaps from bottom to top change, and top gap is actually wider than what will seal.
The rear glass is not smooth in operation, so I am wondering if something is messed up resulting in the back quarter glass needing to be tilted forward?
I honestly can't remember if this was a problem before the paint work, and I am not certain if the glass was removed (Believe the vent window was removed to replace that weatherstripping)
I know nothing about the regulators (where to even lube them to help in operation) so any guidance needs to be dumbed down haha. The interior is not in the car so I have full access
Thx
1967 Satellite, CNC Eddy Headed 500ci Street Mauler (Dyno'ed @ 600 HP / 650 ft-lbs)
2016 Challenger Hellcat - Holy Hell 2012 Hemi Ram Sport Crew Cab 2011 Avenger, Pentastar V-6 2007 SRT-8 Charger (Dyno'ed @ 470 RWHP) 1986 Caravelle, 318, aka "Rosco", Back Road Burner!
ALL Black...Bad Boys always wear Black!
Re: Misaligned Side Glass? - 1967 B Body
[Re: Mills]
#2181618
10/24/16 06:32 PM
10/24/16 06:32 PM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I was able to adjust mine really nicely a few years ago after getting real tired of them rattling around when the door shut.. I don't recall exactly what I did... but... I had the FSM and referred to the instructions about where to make adjustments. Took the door panels off obviously, and made adjustments at the guiderails and the "glass carrier" thingy.... Sorry this is not the specific help you need, but get an FSM and you should be all set.. eh? - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: dynorad]
#2182107
10/25/16 01:06 PM
10/25/16 01:06 PM
Mills
Airdrie, AB
Thx for the replies. I ordered a FSM to help me with this.
I took the attached last night - I think the front side glass is off (body guy did have the vent glass frames out).
Watched a video on YouTube for adjusting all (3) on a old Stang and I assume the Mopar procedure will be very similar.
