Re: Best Battery for a drag car only? And maintenance?
[Re: DemonDust]
#2182514
10/25/16 09:12 PM
10/25/16 09:12 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
If you don't run an alternator you are crazy--the Winners run one!!
I questioned this pretty blunt, bold and blanket statement and he seemed to not agree with my question.
As to solely relying on an alternator, I would have a hard time trusting that. It would take a monster alternator to put out enough amps at low rpm to cover the ignition, fuel pump, water pump, fans, etc. Plus as mentioned, starting the thing 10 times in the lanes to pull it up will zap the battery for sure. Car only sees enough rpm to truly charge the battery for a few seconds during a run. The rest of the time is idle or a little off idle. So hardly seems worth the effort to me on a track only car, since alternator or not, I would personally be running the batt charger after every pass
[Re: DemonDust]
#2182702
10/26/16 12:36 AM
10/26/16 12:36 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
Even if you have an alternator you should be charging between race days for a strip only car. The alternator never runs enough to keep up with the starting and running fans to cool down etc.
My car is a street car but I use my electric pump and fans to cool the car down after every pass. I also do not push it in the lanes I just start it to pull forward. Even though it gets driven to and from the track I always try to put my charger on it when I get home.
68 Barracuda Formula S 340
[Re: DemonDust]
#2182801
10/26/16 05:12 AM
10/26/16 05:12 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
[/quote]You shut your car off at the ET shack???[quote] I actually click it at the stripe. Finish line, neutral, click it. I'm lucky at Sonoma and Vegas because the return road is down hill and I can coast all the way to my pit spot. At Sacramento, I pull off to the side and cool it down while I get out of my safety stuff then fire up and drive to the pit stopping for the time slip. Same as Sac. with Phoenix, Fontana, Seattle, Woodburn and RMR. Hope to do more Sonoma and Sac. this next year. I won't be making the final divisional in Vegas in two weeks due to some health issues.
