Re: 518 into 70 cuda [Re: derekeh] #218076
02/08/09 10:50 PM
02/08/09 10:50 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I also say use the lockup. Since you aren't making it too wild of a motor, it will work fine. Just as a point of reference for you, we have a 92 Dodge B250 van with a 518 in it. It has a lockup convertor. Moparts member Snailpower had a 518 in a 70 Coronet, and did a nice job cutting his crossmember to get it to fit. I don't know if his pics are still in the archives or not. Good luck
Re: 518 into 70 cuda [Re: JDMopar] #218077
02/09/09 12:55 AM
02/09/09 12:55 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Don't you have to shorten your driveshaft as well...
Re: 518 into 70 cuda [Re: DaytonaTurbo] #218078
02/09/09 01:17 AM
02/09/09 01:17 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yes...And you need to increase the trans cooler line size to 3/8ths...
Re: 518 into 70 cuda [Re: 1_WILD_RT] #218079
02/09/09 01:30 AM
02/09/09 01:30 AM
Manitoba, Canada
Manitoba, Canada
A 518 is what, 3 or 4 inches longer than a 727?
Re: 518 into 70 cuda [Re: DaytonaTurbo] #218080
02/09/09 03:00 AM
02/09/09 03:00 AM
hooziewhatsit Offline
Everything I've seen says the driveshaft needs to be 3.5" shorter. So your guess is pretty close
-Dave
Re: 518 into 70 cuda [Re: hooziewhatsit] #218081
02/14/09 01:28 AM
02/14/09 01:28 AM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
So does the floor hump need to be modified in my 70 cuda for a 518 tranny? And where can I get the tranny crossmember or diagram of one?
