Page 2 of 3 1 2 3
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2178422
10/19/16 07:48 AM
10/19/16 07:48 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
So what are my options?
I went with Motive Gears (even though a friend of mine advised against it, he just had a set go bad in 2000 miles in his big block Duster which had been setup by Strange Engineering as a complete assembly) but I wrote it off as a one off incident. Motive had them on the shelf and I was trying to make the Mopar event at the Valley October 8th.
There isn't a great selection of 3.73 for the 8.25" rear. I wanted just enough extra umph out of the hole to hit 12's but not impact the highway rpm's. That is why I stayed away from 3.90/4.10's. Might bump up to 3.90 just to get better selection.
US STANDARD GEAR has 3.90's, never heard of them.
https://www.summitracing.com/int/parts/spz-36010/overview/
Richmond has 3.90's, but not till November.
https://www.summitracing.com/int/parts/rmg-scr82503/overview/
G2 has 3.90's, don't know much about them either.
https://www.summitracing.com/int/parts/gta-2-2029-390/overview/
Yukon Gear 3.90's
https://www.summitracing.com/int/parts/yga-24002/overview/
Gary
"I think its got a hemi"
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2178426
10/19/16 08:09 AM
10/19/16 08:09 AM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
If your pattern is spot on and the backlash is right in the middle of specs then sum it up to gearset quality.
I worked for DCA as technical training instructor and worked on enough DANA's and corporate axles to make me sick. That being said, there are a lot of factors, but at the end of the day if it's setup within specs and still noisy it'll be a gearset issue... Very hard to find stellar gearsets, we even used what they call matched gearsets when we had extreme situations.
"It takes a Mopar to catch a Mopar”
1970 Challenger T/A 4 speed EV2
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2178630
10/19/16 02:18 PM
10/19/16 02:18 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
I've been told, true or not flip or flop don't care, that ratio's above 3.55 can be on the noisy side as they are more a truck ratio, either way it's piss poor with today's manufacturing machinery that we are buying hit and miss sets, it's an install and prey situation today.
That blue box motive is exactly what I have only for a D60 in 3.73. I looked at your first few pictures you posted and straight away though, they will be noisy. The face of the tooth on drive and coast is not smooth they have marks across them from the machining. Mine are the same and I've gone out to 0.011" backlash which helped a little. I will be changing these out as they are loud and horrible, my pattern is spot on in the centre of the tooth.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2178634
10/19/16 02:21 PM
10/19/16 02:21 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
A mate of mine has a set of red box motive 3.54 and they have been lapped btw, too the face is nice and smooth
Re: Ring and Pinion pattern (round two) [Re: crash520] #2178638
10/19/16 02:28 PM
10/19/16 02:28 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
I have run 4.11, 4.56, 4.88 on the street and all are silent compared to this hunk of junk living in my 8.25 rear. My GTX just ran 11.0 at 121 with a silent 4.11 gear set 3 weeks ago.
As a dealer tech I have driven many vehicles with ratios over 3.55 and they make no noise.
This gear set sounds like a dentist drill in the trunk and will be the last Motive set I ever purchase.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2178812
10/19/16 09:25 PM
10/19/16 09:25 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I actually liked the look of the .020 the most. I probably would have tried .022.
.026 or more loks like you're on the edge of the pinion's teeth. The less shim seems to have more the look of "flat on flat", if that makes sense.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2178911
10/19/16 11:45 PM
10/19/16 11:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I will only ad that I have run all of those ratios as well as a 5:13 and they were all quiet. The gears were made MANY YEARS ago but were quiet when set up properly. They were not "RACE ONLY" gears that can sometimes be known for making noise. bad gear set?? bad setup ?? don't know as I have never been trained in reading the patterns. I understand the basic principle but the pattern reading seems almost like black magic shruggy pity
Re: Ring and Pinion pattern (round two) [Re: TJP] #2178997
10/20/16 05:56 AM
10/20/16 05:56 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Which is why I had the vendor who supplied the gear set approve the pattern before running the car.
"You didn't have it setup correct" excuse has just been eliminated.
Edit: I am considering dropping the shim from where it is currently at to .022-.024. Whats the worst that will happen?
Already junk as far as I'm concerned.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2179034
10/20/16 09:46 AM
10/20/16 09:46 AM
moparx Offline
moparx  Offline
maybe your "trunk monkey" has a second job setup in there used for extra cash 'cause you don't pay him enough ? biggrin [i couldn't help myself. just funnin' ya !]
beer
Re: Ring and Pinion pattern (round two) [Re: moparx] #2179079
10/20/16 11:18 AM
10/20/16 11:18 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
haha
And to the OP, you could try it but I'm thinking it'll still be noisy, shruggy beer
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2179493
10/20/16 11:05 PM
10/20/16 11:05 PM
GA
roadrunninMark Offline
GA
Try a different dif oil? Synthetic?
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2179571
10/21/16 12:53 AM
10/21/16 12:53 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Send the gears out to get REM finished. They will be smooth after that. Might work.
http://www.taylor-race.com/isotropic.cfm
Gears need to be set up before REM process and save all shims. You will not get a gear contact pattern afterwards.
Re: Ring and Pinion pattern (round two) [Re: NANKET] #2179605
10/21/16 07:11 AM
10/21/16 07:11 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
They will go in the trash before I put any more money into them, thanks for the suggestion though.
Just having a run of bad luck this month.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2179607
10/21/16 07:17 AM
10/21/16 07:17 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Anyone have any feedback on these four companies? Yukon and Richmond I'm familiar with, the other two not so much.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2179626
10/21/16 09:17 AM
10/21/16 09:17 AM
moparx Offline
moparx  Offline
back in 2003, i sent for info on o.d. systems like the gear vendor unit. one of those was a unit from U.S. Gear corp. at that time, that was who made strange parts. i don't know if U.S. Standard Gear is the same outfit or not. maybe a name change ? an economy version of the strange gear set ? i don't know, but that is the only thing that comes remotely close that i have dealt with. by the way, their o.d. unit looked like a quality part and was several hundred dollars cheaper, a couple inches shorter than the gear vendors unit, and the info came with an additional $200.00 off coupon to boot. i never acted on any o.d. unit at that time. for reference, the U.S. Gear Corp. had a chicago address.
beer
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2180177
10/22/16 07:27 AM
10/22/16 07:27 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Richmond I'm inclined to go with since they have been around forever but that doesn't seem to mean much these days.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2180247
10/22/16 10:50 AM
10/22/16 10:50 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
US STANDARD GEAR - from what I have heard are over stock or non spec. Yukon GEAR
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2180306
10/22/16 12:33 PM
10/22/16 12:33 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
We have installed several Richmond sets and had pretty good experiences with them. Some have made a small amount of noise but very minimal and the customers have found it to be acceptable. beer
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2180371
10/22/16 03:10 PM
10/22/16 03:10 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I installed a set of the G2 gears (3.54:1) in the Dana 60, and they are quiet. I never heard of G2 before, but the seem fine so far. Only have about 1500 miles on them.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2180394
10/22/16 04:10 PM
10/22/16 04:10 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Interesting.
Pulled everything apart again this morning after an hours run time and dropped the shim from .026 to .023 and set the backlash at .009
The noise moved up about 10 mph from where it was and seems to be in a more narrow window, it also sounds a touch more quiet.
Dare I move another .003 or just leave it the hell alone? I am getting tired of disassembling my 8.25" over and over. Good practice. I'll post the new pattern in a few hours.
The marks on the teeth look very, very coarse. I have my doubts about how well they were "lapped in" from the factory.
Gary
Page 2 of 3 1 2 3
