Re: MuuMuu's 68 Dart... It's a Learning Process...
[Re: MuuMuu101]
#2151023
09/09/16 01:37 PM
09/09/16 01:37 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I was playing around with different gauges to try to find the best place for a tach and I'm still undecided. There is a guy on FABO that sells a tach bracket that gets sandwiched between the dash frame and the upper pad.
[Re: MuuMuu101]
#2171136
10/09/16 09:53 PM
10/09/16 09:53 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
Finally, light at the end of the tunnel! Take it real easy on your shakedowns...
Old, tired, and sometimes broke down. Me, not my car...
[Re: MuuMuu101]
#2171173
10/09/16 10:41 PM
10/09/16 10:41 PM
moparpollack
Lil Herman
Lil Herman
85086
I'm supposed to pick it up sometime this week. As in done... done. They're having a problem with the wiring harness under the dashboard. So see you at Fall Fling! ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Shoozy]
#2171292
10/10/16 01:59 AM
10/10/16 01:59 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Finally, light at the end of the tunnel! Take it real easy on your shakedowns... Definitely. I barely found collector car insurance for it, but I need the car because I have to have pictures of the car completed from all angles.
[Re: moparpollack]
#2171293
10/10/16 02:00 AM
10/10/16 02:00 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I'm supposed to pick it up sometime this week. As in done... done. They're having a problem with the wiring harness under the dashboard. So see you at Fall Fling! If you're going to be out here, give me a holler!
[Re: MuuMuu101]
#2171312
10/10/16 02:53 AM
10/10/16 02:53 AM
moparpollack
Lil Herman
Lil Herman
85086
I'm supposed to pick it up sometime this week. As in done... done. They're having a problem with the wiring harness under the dashboard. So see you at Fall Fling! If you're going to be out here, give me a holler! I'll be there for sure! ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
