Re: Went on the chassis dyno today. Any guesses?
[Re: Charger453]
#2179385
10/20/16 09:37 PM
10/20/16 09:37 PM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
As for the converter, I paid attention to trap RPM the best I could the last time I was at the track. According to Wallace's slip calculator, I'm 18%-20%. The question is: how low can you expect it to be in a combo like this only running 3.55s in the 1/8? Hell, I can cross the stripe around 7,200-7,300 in 2nd. Figured I'd try that once.lol Would a single digit slip number be too tight in this case and bog the motor down? Those will be my questions for PTC. Nice numbers! I'm curious, how much did your car slow down when you crossed the line in 2nd gear? I have a 500" pump gas duster street car with a 9.5" fairly tight converter and 3.23 gears. I've been kinda wanting to drive to the track and run a low 11 second pass with the 3.23 gears. Motor makes plenty of torque.
[Re: Charger453]
#2179441
10/20/16 10:39 PM
10/20/16 10:39 PM
ProSport
Akron, Ohio
As for when I crossed in second, I can't find a couple splips and that's one of em. I believe it was a low 6.60 @ 107.6 or so??? Wow that's impressive crossing in 2nd. Have you ran it with a steeper gear? I'm just curious how much you think it slowed it down.
[Re: ProSport]
#2179461
10/20/16 11:10 PM
10/20/16 11:10 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
As for when I crossed in second, I can't find a couple splips and that's one of em. I believe it was a low 6.60 @ 107.6 or so??? Wow that's impressive crossing in 2nd. Have you ran it with a steeper gear? I'm just curious how much you think it slowed it down. It probably did not slow him down much. I was running 5.14 gears that was probably not low enough for my combo and broke them and changed to 3.50 gears and only lost 5 hundredths in the 1/8. 6.34 @ 108 to 6.39 @ 109 crossing the finish line in 2nd gear.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Charger453]
#2179628
10/21/16 10:19 AM
10/21/16 10:19 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
That is one beautiful Charger!!!
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Charger453]
#2179730
10/21/16 02:19 PM
10/21/16 02:19 PM
Posts: 19,537 Las Vegas
Al_Alguire
Las Vegas
Always loved the car and it makes good power. To bad you guys don't have a 1/4 mile track to race at anymore. Awesome ride!
