Page 3 of 3 1 2 3
Re: Rod knock or Cracked Flexplate or ?? [Re: Nitrofish] #2206610
12/02/16 06:53 PM
12/02/16 06:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes it does.. you have clearance there
wave
Re: Rod knock or Cracked Flexplate or ?? [Re: Nitrofish] #2206733
12/02/16 10:53 PM
12/02/16 10:53 PM
USA
N
Nitrofish Offline OP
N
USA
I knocked a couple of the cam bearings out and measured the diameter of bore in the block. So far they are smaller then spec as many have already suggested and also what I believed in my gut...
I may attempt to increase the bore diameter with a hone. Looks like there is currently another post here on Moparts regarding this very thing.
Re: Rod knock or Cracked Flexplate or ?? [Re: Nitrofish] #2206885
12/03/16 10:45 AM
12/03/16 10:45 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
My first thought looking at that rod and bearing cap is either a non-c bearing was used or if it was then somehow someone mixed up, the upper and lower halves.
Re: Rod knock or Cracked Flexplate or ?? [Re: Nitrofish] #2207031
12/03/16 03:54 PM
12/03/16 03:54 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
My 440 had the same exact knock. After removing the engine and placing on the stand, it turned out to be loose crank pulley bolts. Bearings all looked new. Can't believe I removed the engine and went through all of that for stupid loose bolts on the crank pulley, but no one to blame but myself.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Page 3 of 3 1 2 3
