Page 1 of 3 1 2 3
Ring and Pinion pattern (round two) #2174851
10/14/16 09:11 PM
10/14/16 09:11 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
On my 8.25 pinion I went from a .031 shim pack to .028, both with .008 backlash. Am I going in the wrong direction?
Trying to get this buttoned up this weekend.
Thanks!
"I think its got a hemi"
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2175143
10/15/16 10:17 AM
10/15/16 10:17 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Had an hour to kill before heading to the post office this morning, tried a big move to a .020 shim to see what the pattern does.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2175144
10/15/16 10:19 AM
10/15/16 10:19 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Watching the pattern moving about and I wrong thinking around a .024 would be spot on?
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2175230
10/15/16 12:20 PM
10/15/16 12:20 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Looking at the movement on both patterns between the 31-28 and then 20 I think I would try the 24... twocents
...FAFO...
Re: Ring and Pinion pattern (round two) [Re: skicker] #2176354
10/16/16 08:05 PM
10/16/16 08:05 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Ended up with .026 tonight, had a hard time getting a good picture.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2176380
10/16/16 08:24 PM
10/16/16 08:24 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Looks good to me right in the sweet spot.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2176737
10/17/16 10:08 AM
10/17/16 10:08 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It's amazing how much more tooth contact you can get with a small move. Even though it is slightly deeper in the root I like it better.
Doug
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2176970
10/17/16 02:31 PM
10/17/16 02:31 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
Maybe just a little more backlash???
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2177027
10/17/16 03:38 PM
10/17/16 03:38 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Already on the loose side at .008
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2177355
10/17/16 10:33 PM
10/17/16 10:33 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Cleaned everything well and assembled with crush sleeve, again backlash at .008
Ran car on the lift for several minutes, no noise noted.
Went out on a road test, gear whine at very light throttle 50-65 mph and then seems to go away at that point. Silent below, silent above. Very slight whine on decel from highway speeds.
Youtube video of noise, had a camera on the back seat. Ignore the electric fuel pump buzz.
https://youtu.be/mvQuNokQ6L4
Anything I can adjust or am I screwed? Diff was a little warm after 15 minute road test, about 230-250F I'm guessing by feel. Pattern was approved by vendor. I'm ready to set car on fire.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2177441
10/18/16 12:15 AM
10/18/16 12:15 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Some gears do whine a little.
Can not tell much from your audio
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Ring and Pinion pattern (round two) [Re: moparts] #2177514
10/18/16 05:41 AM
10/18/16 05:41 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
I'll try and do a better one tonight, its loud though when its in "the zone" louder than it should be.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2177773
10/18/16 03:27 PM
10/18/16 03:27 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Vendor told me to drive it 500 miles and then change the break in oil.
Never heard of a gearset getting quite over time.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2178092
10/18/16 08:26 PM
10/18/16 08:26 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
https://youtu.be/0SZzoAEZSb4
Camera in trunk, short clip
Put about 30 miles on car tonight, no notable change.
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2178209
10/18/16 10:27 PM
10/18/16 10:27 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree pity
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2178230
10/18/16 10:44 PM
10/18/16 10:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Pattern looked pretty good. With this gear set my bet is this is as good as it gets.
Doug
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2178275
10/18/16 11:37 PM
10/18/16 11:37 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
What brand gears? I installed blue box Motive, load as all get out, am going to get a set of OEM Spicer gears to hopefully make it better
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2178277
10/18/16 11:38 PM
10/18/16 11:38 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
I'd still try opening back lash a little
Re: Ring and Pinion pattern (round two) [Re: crash520] #2178401
10/19/16 05:50 AM
10/19/16 05:50 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Motive Gear C8.25-373
Re: Ring and Pinion pattern (round two) [Re: dvw] #2178402
10/19/16 05:53 AM
10/19/16 05:53 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Doug
Not acceptable.
I'll try moving the backlash out a touch and see if there is any improvement but if this is "as good as it gets" with this brand... I'll have future plans to replace them with a different brand and take the loss.
Page 1 of 3 1 2 3
