Page 2 of 3 1 2 3
Re: Edelbrock of idle stumble 440 engine [Re: dogdays] #2182688
10/26/16 12:25 AM
10/26/16 12:25 AM
fury4speed Offline OP
Here is what I did , it runs and there is no stumble off of idle , at all , this worked for me.
Drilled out the accelerator nozzles to .045 (went to .041 first)
Installed the .113 primary jets
Installed the .073 X .037 metering rods
Installed the stiffest metering springs
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2182748
10/26/16 02:03 AM
10/26/16 02:03 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Did you ever check the fuel level in the bowls?
I did the same thing you did, made the carb "work" with what should be a really rich setup. Then I adjusted the float level for more fuel in the bowls and had to back those changes out because the carb was too rich.
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2182757
10/26/16 02:22 AM
10/26/16 02:22 AM
its all good now but I'm wondering if drilling the nozzles is what did the trick
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2182869
10/26/16 10:55 AM
10/26/16 10:55 AM
MD
p d'ro Offline
p d'ro  Offline
MD
This is close to where I am at so I hope it runs once I finally get going.
Can you give a brief description of your motor specs/parts as it would help..
Re: Edelbrock of idle stumble 440 engine [Re: p d'ro] #2182887
10/26/16 11:19 AM
10/26/16 11:19 AM
I changed the rods (smallest diameter that I had first and no change or big change that I could notice
I drilled out the nozzles to .041 next and that made a difference
I changed the springs to the weakest springs , made it worse (I guess that seemed to hold them down in the jets longer so maybe a lean condition
I change back to the strongest springs and that was better
I drilled out the nozzles to .045 and that helped a lot
I ordered a marine accelerator pump as I read where that makes a difference p/n is 1468 but it is still on the way here and I have not installed it
I guess it was a all around lean condition , the floats were fine and were at 7/16
Re: Edelbrock of idle stumble 440 engine [Re: p d'ro] #2182890
10/26/16 11:26 AM
10/26/16 11:26 AM
The engine is a 440 , edelbrock intake and 1411 carburetor , cam is suppose to be a mild cam , I bought it this way so I have no idea what it is the engine.
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2182927
10/26/16 12:48 PM
10/26/16 12:48 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I put a quick fix on my stroker 500", edelbrock 800 carbed, 400 bb, by stretching the springs about 1/8". It helped lift the rods enough to lose the flat spot. I had tried all the pump settings beforehand.
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2185254
10/29/16 01:21 PM
10/29/16 01:21 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
I tried everything previously mentioned (except streach the springs) and I could not get rid of the off-idle dead spot. I even tried a new 800cfm after giving ip on the 750cfm. I also have a low vacuum cam that makes it worse in my 440. The only fix for mine was a different brand carb.
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2185442
10/29/16 07:46 PM
10/29/16 07:46 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Occasionally the idle circuit will not feed enough fuel depending on the combo. Opening the idle feed tubes will usually fix it.
Doug
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2185696
10/30/16 07:33 AM
10/30/16 07:33 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Anyone looking to part with one of these troublesome 750 cfm devices drop me a PM. I'll install it on my Duster which has wide band and have a look see.
Gary
"I think its got a hemi"
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2185748
10/30/16 11:43 AM
10/30/16 11:43 AM
74RALLYE Offline
74RALLYE  Offline
I sold the 750 already. I still have the 800 if your interested. $150
PM me if you want it.
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2186721
10/31/16 02:35 PM
10/31/16 02:35 PM
MD
p d'ro Offline
p d'ro  Offline
MD
I am with you and mine may be for sale. Just instralled nue acc. pump and the 43 squirter to no avail. Either the butterflies/weights are not kicking in the secondaries soon enough, or there is another issue. I actually need to peer in and make sure not a mechanical issue there restricting the opening. They eventually open, jsut not right away..
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2186777
10/31/16 03:34 PM
10/31/16 03:34 PM
I have read where the marine accelerator pump works better as the spring is stronger and will push more gas out of the nozzles without collapsing the stock spring , never tried it though , the part number is Edelbrock 1468 , mine is working a lot better now , virtually no hesitation of idle.
Re: Edelbrock of idle stumble 440 engine [Re: p d'ro] #2186799
10/31/16 04:01 PM
10/31/16 04:01 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I have finally ended up with one of these notorious carbs, never had any problems with the 600 and 800's that a little tuning did not straighten out.... till now. I acquired a brand new 1411 for free. I put it on a mild 440, 240@50 cam, Holley SD intake and proceeded to tune. Big off line stumble, the distributor needed more initial and a curve anyway, so I bought the plate kit from FBO that allows you to limit total timing in the older MP dist, without having to play the braze up the slot and file game. This thing is great and this particular engine is very happy with 20* initial, 34 total, and using the vac advance adjusted to add 10 at idle on the full time vac port as recommended by FBO. Before I got the plate , I had tried the .043 squirter,HP orange(marine) acc pump plunger, and played with the jet metering rod combos until its infamous off line bog was almost gone, but not quite! Getting all of the timing issues squared away finished it off and made the car a joy to drive under all conditions but one. If you are at a complete stop and floor the throttle, it literally dies! You can hit the throttle briskly and smoke the tires, ease into the throttle and spin tires, but if you mat it, it dies! Pump is at max shot, passages are clear, and it will die every time if you mat it from a standing start, if you are already moving, no problem! it is like it is going massively lean. The floats are perfect, I am frustrated as the devil! I can put the tuned 1406 6oo cfm carb on it and it will come off the line sideways, same with my 800 performer, but that ****###@@ 750 has me stumped. It works great except that one situation. No bog in any other form of accelerating, just full bore from a standing start! Any ideas on this one??? Lee.
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2186863
10/31/16 05:55 PM
10/31/16 05:55 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Just use the google search on top of the Moparts page and enjoy all the lovely threads on the 1407/1411 off idle stumble , and then sit back for a month reading all 10,000 threads on how to fix it
Do you own a drill , a reciprocating saw , hammer , open wallet , and have unlimited time on your hands ???
Perfect , then the 1407/1411 is the carb for you
LOL
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2187153
11/01/16 12:29 AM
11/01/16 12:29 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Have ANY of you ever tried drilling the idle feed tube, changing air bleed size? Or is it easier to give up and complain? People will change metering blocks, air bleeds, squirters, squirter cams in Holleys till they turn blue. Heaven forbid you try something on a Edelbrock besides squirters, springs, rods or jets. Think outside the box. If it's lean, richen it up. It's still just a carb. Is it a full race Holley, absolutely not. Can they be a decent carb, yes.
Doug
Re: Edelbrock of idle stumble 440 engine [Re: dvw] #2187269
11/01/16 10:36 AM
11/01/16 10:36 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Doug
iagree It's not rocket science. Look into almost all NSS cars and this is the carb they run and do not have these issues that every one is complaining about. I actually tried the 800's for the last 2 years and then decided to go back to the 750's as my 60 ft times were better and so was my ET. Had a small bog at first and lightened up the rear air doors and the bog is gone.
Re: Edelbrock of idle stumble 440 engine [Re: fury4speed] #2187313
11/01/16 12:26 PM
11/01/16 12:26 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
I didn't realize the NSS cars leave the line "OFF IDLE"
Thanx for clarifying that
LOL
Anyways
I tried drilling the idle tubes on my 1407 - Didn't work or help or change anything
On the street , daily driver , "OFF IDLE" the Edelbrock 800 series AVS is 1,0000 times better the carb
Siberian Huskies
Re: Edelbrock of idle stumble 440 engine [Re: Lee446] #2187343
11/01/16 01:30 PM
11/01/16 01:30 PM
MD
p d'ro Offline
p d'ro  Offline
MD
This is mine to a tee. But mine dies flat from stop or while moving, then kicks in hard. A little scary as it breaks loose and gets a little wild. Probably won't address it til springtime.
Re: Edelbrock of idle stumble 440 engine [Re: bee1971] #2187525
11/01/16 05:49 PM
11/01/16 05:49 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
LOL
Anyways
Many do. Mine will, but for reaction time I leave higher.
Doug
Page 2 of 3 1 2 3
