Milled head surface finish
#2175127
10/15/16 09:45 AM
10/15/16 09:45 AM
Posts: 2,425 west palm beach, florida
modelmakerinc
Guys, these heads came off the 383 I am installing, just a freshen up with a small cam and springs, these heads had just been done a couple years ago, I am cleaning up the surfaces to reinstall the heads and notice an aggressive mill surface, you can feel the ridges with your fingers and sounds like a zip tie with your nails. I am going to use fel-pro perma-torque but concerned with this surface. It is typical on both heads
The motor ran fine prior and did not have any issues, but my concern remains.
Thoughts...
Re: Milled head surface finish
[Re: twayne24365]
#2175163
10/15/16 10:47 AM
10/15/16 10:47 AM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Cometics NO, Felpro Permatorks that will be fine. Slap it together.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: Jeremiah]
#2175465
10/15/16 08:10 PM
10/15/16 08:10 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That was VERY common for us oldtimers to see heads finished like that and our gaskets never moved. LOl As a matter of fact I bought a 555 but never got it running and finally sold it.
[Re: modelmakerinc]
#2175501
10/15/16 09:06 PM
10/15/16 09:06 PM
Posts: 44,005 Bend,OR USA
Cab_Burge
[Re: Jeremiah]
#2175873
10/16/16 09:46 AM
10/16/16 09:46 AM
Posts: 2,118 Apollo, PA.
B1MAXX
Apollo, PA.
What machine makes that kind of surface finish? Van Norman 555? I'm not sure I have seen factory heads that rough. 555 is a grinder...those are cutter marks.... feed was too fast Some machines only have pre set feeds.
[Re: modelmakerinc]
#2175926
10/16/16 10:53 AM
10/16/16 10:53 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I remember that finish. Using Felpro, MP or Dvorjak Detroit gaskets never was an issue, although Felpro's gave me a problem when I started stepping up compression.
[image][/image]
[Re: sgcuda]
#2175935
10/16/16 11:02 AM
10/16/16 11:02 AM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I remember that finish. Using Felpro, MP or Dvorjak Detroit gaskets never was an issue, although Felpro's gave me a problem when I started stepping up compression. Wow not me. That's the only way we got our junk to run 9's forty years ago with crap 906 heads and TRW Pistons. Over cam, over carb, and over compression.
[Re: modelmakerinc]
#2175940
10/16/16 11:09 AM
10/16/16 11:09 AM
sgcuda
I was using a lot of Direct Connection parts back then. Tried to get into the 9's. Started breaking a lot of .690 mushroom cams, lifters, battleship springs. Final straw was when DC rod bolts were letting go. Was always shifting under 7,000. Finally changed machinists, and went away from DC.
[image][/image]
[Re: modelmakerinc]
#2175950
10/16/16 11:19 AM
10/16/16 11:19 AM
sgcuda
I found the Felpro standard gasket to work better than the race gasket. But still blew at 12+ compression. When I contacted Felpro, they said that their gaskets are only rated for 12:1.
[image][/image]
[Re: sgcuda]
#2175968
10/16/16 11:37 AM
10/16/16 11:37 AM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A very good Friend of mine taugh me an old NASCAR secrete that worked great with cast iron heads. We would take a counter sinking tool and cut a 45 degree cut around each head bolt on the head deck surface. It would spread the pressure across the head instead of directly under the head stud bolt area.
[Re: pittsburghracer]
#2175980
10/16/16 11:56 AM
10/16/16 11:56 AM
B1MAXX
Apollo, PA.
A very good Friend of mine taugh me an old NASCAR secrete that worked great with cast iron heads. We would take a counter sinking tool and cut a 45 degree cut around each head bolt on the head deck surface. It would spread the pressure across the head instead of directly under the head stud bolt area. loved hanging around that dude
[Re: B1MAXX]
#2175982
10/16/16 12:04 PM
10/16/16 12:04 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A very good Friend of mine taugh me an old NASCAR secrete that worked great with cast iron heads. We would take a counter sinking tool and cut a 45 degree cut around each head bolt on the head deck surface. It would spread the pressure across the head instead of directly under the head stud bolt area. loved hanging around that dude You and I both
[Re: modelmakerinc]
#2176082
10/16/16 02:23 PM
10/16/16 02:23 PM
Posts: 14,547 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The machines used for engine rebuilding have evolved quite a lot in the last 30-40 years.
I'm not sure if my head surfacer could even produce a finish as coarse as what's in the OP's pics.
A shop i worked at over 20 years ago had a pretty nice wet grinder type head surfacer, and if you ran the table feed up pretty high it would produce a finish like in the pics.
#2176355
10/16/16 08:07 PM
10/16/16 08:07 PM
sgcuda
A very good Friend of mine taugh me an old NASCAR secrete that worked great with cast iron heads. We would take a counter sinking tool and cut a 45 degree cut around each head bolt on the head deck surface. It would spread the pressure across the head instead of directly under the head stud bolt area. Now you tell me. Where were you when I needed you 30 years ago?
[image][/image]
