Re: Green bearing [Re: JL2] #2178509
10/19/16 12:34 PM
10/19/16 12:34 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
See, the pissing has a started. How about this, find out why they are going bad so soon, and fix that, but on the other hand, IF you do decide to go back to tampered bearings do not buy them from an auto parts store, as those are off shore, even the Timken ones. You need the actual bearing and race number and go to an industrial supply house and get US made Timken bearings, there is a difference.
Re: Green bearing [Re: JL2] #2179007
10/20/16 08:53 AM
10/20/16 08:53 AM
Louisiana
JL2 Offline OP
JL2  Offline OP
Louisiana
Thanks again for all of your input of my troubles. Now one more question or two about the 8.75. When I purchased this 489 from the guy, he told me that it was originally an E-body part and he cut it down for the A-body. Outside length is 52.5" now and axles are 27-1/8" in total outside length. Someone mentioned to me that if the measurement of the housing and axles are not to spec, then the thrust block in the diff needs to be removed. Are there any tolerances on these numbers, are mine good enough to not have to remove the thrust block? If I don't have to, I don't want to.
Re: Green bearing [Re: JL2] #2179221
10/20/16 04:10 PM
10/20/16 04:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Stock A-body housing width is 52 5/8", the stock axles are 27 11/16". BBP conversion axles should measure 28".
How are you measuring the axles? Outside of flange to tip of splines is the correct way.
Re: Green bearing [Re: John_Kunkel] #2179237
10/20/16 04:52 PM
10/20/16 04:52 PM
Louisiana
JL2 Offline OP
JL2  Offline OP
Louisiana
Man o man I guess my coffee didn't open my eyes this morning when I read the tape, lol, the axle length from end to outside is actually 27-11/16". Thank you again.
